Solved Same problem and my crazy computer
mezda
12:16 AM
all remeber my problem and i said i solved with my self ,but my Computer was fooled me. after solved proplem
ifound proplem at CD at setup
and i I set up new windows xp while i will buy new windows 7
after i bought it and put it in cd i have the same problem again
and i put the old cd (that lag at setup)Wright said the problem has returned again
so i do my i tried my The solution but still with same proplem
I think my computer is crazy
this is the problem :
my solution work for one time but the another time it didn't do any thing there is the solution and it's scanned by avira 2012
mezo.rar
please help me in this problem
{:eek:sorry for bad english}
[ecs-945g]intel 945g/gz/gc/p/pl mother borad type NEC
Windows XP 32bit
intel celertom d 3.0.6GHz
type nec
2giga ram kingston
itel GMA 950 it's power 234mb
realtek ac97 audio
Philips
1024x768
4 hard drivers
SATA:PM_WDC WD1600
idk
idk
idk
IBM
Fire
512 mb
Where did you get Win7? Did you burn the DVD yourself? If so burn another at 4x speed with ImgBurn, or write to flash stick using Universal USB Installer. Unplug the DVD drive when trying flash stick install.
If these methods fail then it is likely the ISO, because this error is almost always the installer.
i have 2 cds one i bought and other was burnt
not by me and the speed was less than4x
Windows XP 32bit
type nec
2giga ram kingston
realtek ac97 audio
Philips
1024x768
4 hard drivers
SATA:PM_WDC WD1600
idk
idk
idk
IBM
Fire
512 mb
Are you receiving the same error using either DVD? Check that both are clean and unscratched.
Next try the flash stick install to see if the same error occurs. If so unplug the DVD drive to try it again.
my bios is old i can't do that and my dvd new and good
did you look to this folder i but it
Windows XP 32bit
type nec
2giga ram kingston
realtek ac97 audio
Philips
1024x768
4 hard drivers
SATA:PM_WDC WD1600
idk
idk
idk
IBM
Fire
512 mb
My BIOS on this laptop is ten years old and it can boot a flash stick. Have you tried it?
Reset the BIOS to defaults. Check that SATA controller if you have it is set to AHCI first to try install.
Next wipe the HD to try install: SSD - HDD Optimize for Windows Reinstallation
It's very unlikely Win7 doesn't have the storage controller but if it's an old IDE one then you can try loading it at Load Drivers link on screen you captured there.
Windows XP 32bit
type nec
2giga ram kingston
realtek ac97 audio
Philips
1024x768
4 hard drivers
SATA:PM_WDC WD1600
idk
idk
idk
IBM
Fire
512 mb
Unplug the floppy disk drive as it can interfere.
Often times the option to boot from USB stick will not appear until you plug in the bootable stick. Then use the one-time BIOS Boot Menu hotkey at boot to boot the stick under USB, Removable or HD's - with HD set first to boot in BIOS setup.
the first DVD it's orignal i got it gift while i buy something for computers
second dvd i got copy of it from my friend
are you happy now?
Windows XP 32bit
type nec
2giga ram kingston
realtek ac97 audio
Philips
1024x768
4 hard drivers
SATA:PM_WDC WD1600
idk
idk
idk
IBM
Fire
512 mb
i try to setuped the second dvd for another laptop and it works and no proplems
Windows XP 32bit
type nec
2giga ram kingston
realtek ac97 audio
Philips
1024x768
4 hard drivers
SATA:PM_WDC WD1600
idk
idk
idk
IBM
Fire
512 mb
