Samsung 23 inch LCD LED resolution problems
kschwarz2002
2:36 PM
Would anyone know the root cause for this problem.
23 inch monitor with HDMI to HDMI conection. Native resolution is correct, although the Windows screen on the monitor is just a little too big. i.e Start button is half off the bottom left corner and when a window is maximized, the minimize, maximize and close buttons of the window are just off of the top right hand corner.
Would this be a Monitor driver problem, Inegrated graphics card problem, or Windows 7-64 bit problem?
any suggestion would be helpfull on how to resolve or where to look for a fix.
Thanks!
Gateway
Windows 7 Pro 64-bit
Intel i3
6gb
Intel AGP-HD
Samsung LCD-LED 23 inch
check your drivers would be my first port of call, have you done an "auto config" on the monitor? ie let it adjjust itself to the display?
Intel Core i5 7400 @ 3.00GHz
OEM supllied with PC
Realtek
Acer Al1980 + HKC
1TB Toshiba
1TB WD Caviar Green
120GB Samsung Evo 840
OEM Supplied
Logitech Wireless
Logitect Wireless
40Mb/s Down 10Mb/s Up
Defender
Thanks!
Why do you have it in HDMI? If it doesnt have DVI, then its not a monitor, its a tv. Your intergrated graphics card isnt that great. Thats a business machine, not a gaming/multimedia one. If you have DVI, connect it there.
Acer Veriton m261 (modded)
Win 7 pro 64-bit, Ubuntu 9.10 64-bit
Intel Core 2 Duo 2.60 Ghz
Whatever came with the system
4 gb ddr2 667 Mhz
NVidia Geforce 9400 GS 1 gb ddr2 550 mhz GPU
Intergrated
samsung SyncMaster 2494 24"
1080p
80gb - IDE
750gb - SATA II
whatever came with the system
Apple Aluminium (Awesome)
Some awesome Dell mouse, really good.
100mbps
A fix for a Samsung Monitor
Man, I apologize for coolness' entirely unhelpful reply.
I had the same problem with my Samsung LED. I finally found the solution after a good bit of time and searching. The problem is that the Samsung LED automatically switches to AV when you plug in an HDMI cord. This makes it blurry, streaked, and not fit correctly. Why they do this I have no clue.
Fixing it is easy. Just go to the menu, go to setup & reset, then down to PC/AV mode. Switch it to PC. This should clear the problems right up. If you made any changes to the screen though you'll want to undo those (I had used ATI to make my screen bigger through the software--I had to undo these changes to get it to look how it was supposed to).
It sucks because you posted that back in January and it took this long for someone to propose a solution....
