Sapphire HD5770 D4000 red led issues. Fan problems?
belnades
4:31 AM
Hi, I've been having issues with my HD5770 for a while now and I'm looking for some help.
For the longest time, my graphics card worked perfectly with my computer and everything was fine, I never had cooling issues or anything like that and there really were no problems. Recently my computer would power up for a little while, seem to be working alright, but then shut off if you tried to use it for an extended period of time. Consecutive uses would make the computer shut off earlier than it had the try before, so I assumed the card was overheating. When I opened the case to have a look, I noticed that the D4000 red led was lit and googled for similar issues to my own, and it turned out that the led was related to overheating issues.
When I looked inside the case I noticed that while the fan was turning, it was bugging along slowly and not spinning correctly. I decided to take the card out, apply new thermal compound (along with my CPU) and then put the components back in. Since using the thermal compound (and compressed air to clean the fans and heatsinks), the CPU purrs and is a lot cooler, but the GPU does not work at all.
Now when my GPU is put back in the machine, the fan does not turn at all. All 3 green leds on the card light up and it seems to run fine for a little while, as it had before, but it eventually shuts off (as there is no fan movement) and again, consecutive uses shorten the amount of time the GPU works. I've taken the GPU out again, but I'm clueless about what to do next, should I buy a new fan? There is no debris in the fan and when I spin it lightly with my finger it seems to spin perfectly? Although there is no resist from the fan at all, it is completely loose. I don't know if that is a bad sign.
The GPU is just over warranty by a few months. I also have no idea where to buy a new fan if that's what I need.
Thanks for reading!
Did you plug the fan connector back to the GPU PCB? If you say it will not spin at all after you dissassembled.
Also, try using MSI afterburner to regulare your fan RPM's and see if it works with that.
Windows 7 professional X64AMD A10-5800K OC@ 4.4Ghz.8GB Kingston HyperX Blu 1333mhzXFX HD7870 2GB Core Edition
Gigabyte F2A85X-UP4
Acer AL2216W
Seagate Barracuda 500gb 7200rpm
Seagate Barracuda 1.5TB 7200rpm
Cooler Master Silent Pro M 850W
Thermaltake Commander MS-I
Cooler Master N520
Logitech M504
10Mbps
I did reattach to the PCB. I cannot turn my computer on long enough to check MSI afterburner. There is no spinning at all, no RPM.
Can you put another fan on the PSU? As in.. a non computer fan, to give it at least some airflow to check if MSI afterburner can regular the rpm?
And by any chance do you use speedfan?
Gigabyte F2A85X-UP4
Acer AL2216W
Cooler Master N520
Logitech M504
10Mbps
I don't own another fan, I don't use speedfan. :(
Well in that case it seems to be a hardware issue.
Pitty that you took it appart and replace the paste. You would have still been able to request support from sapphire, but I doubt they will take it back to have it checked now that it has been disassembled.
Gigabyte F2A85X-UP4
Acer AL2216W
Cooler Master N520
Logitech M504
10Mbps
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
