hey guys, i need a hand with my monitoring.
i have just installed a radeon 6870 (which supports 6 monitors. it has 2 hdmi outs, 1 dvi out and 2 mini dvi outs. i want to set up 2 monitors. i currently have 2 hdmi cables going to my lcds, but windows 7 will only register the main monitor. in the display settings there is no second monitor and no option to extend the dekstop across the 2 monitors. the 2nd lcd is showing no signal even though it it plugged in correctly.
any ideas? also i was thinking of getting dvi cables as the images are sharper, but would i have the same problem using the mini dvi outs?
any help is appreciated.
thanks,
james
thanks,
james
windos xp 32 SP3i7 - 9206gb ddr3sapphire x1800xt
- windos xp 32 SP3
- i7 - 920
- Motherboard
- gigabyte ex58-ds4
- 6gb ddr3
- Graphics Card(s)
- sapphire x1800xt
- Hard Drives
- 4x seagate 1tb
