Sony Vaio Stuck on welcoming screen, with no way to help?
Ruvik
11:46 AM
Heres the story....i would try to go in safe mode and such but my laptops screen is cracked meaning im using a monitor and it doesnt show until it gets to the screen where you choose your user.
I need this fixed badly if theres any way anyone can help me please im desperate.
I have extremely important files on that PC. My job requires those files back. and now i feel im screwed and im scared it all lost forever.
Please,,,any advice? or anything to do? If needed ill post a video of what i mean but its only a stock sony vaio nothing fancy. Please guys im not tech smart and i apollogize for sounding stupid but understand..
Thank you for taking the time to read this!
64 bit windows 7 home premiumunknownunknownAMD
Sony Vaio
unknown
unknown
unknown
AMD
Sorry i dont know much about computers to tell you..
Malwarebytes premium edition.
Chrome, Firefox.
It is normal that a laptop won't use an external monitor in pre-OS environment. You won't lose files because of this. However, you should be backing up your user/data files when everything is running normal, because it may not be so tomorrow!
See Notebook screen busted, display refuses to work pre-OS : techsupport
Edit: Some laptops do have such a feature but it is normally a premium one.
Windows 7 Ultimate x64 SP1AMD Phenom 2 1090T2x8GB Kingston HyperX Fury Black 1600Mhz Unga...MSI GTX 970 Gaming 4G
AMD Phenom 2 1090T
Gigabyte GA-890FXA-UD5
3xAcer GD245HQ
HighPower 1000W
Cooler Master HAF 932
Noctua NH-D14
Logitech G19
Logitech G500
IE 11 - Firefox - Chrome
Thank you for the reply and link! I guess i should just get the screen fixed but even so how will i be able to fix the problem im having without having to reset the whole system back to factory settings? because most of the time im always told thats the only way and theese files are extremely crucial for me to get back :/
Sony Vaio
unknown
unknown
unknown
AMD
Chrome, Firefox.
Use the Force! :)
Use intuition, start the laptop, and tap F8 every second or so, do this for, say, 30-40 seconds (hopefully opening Advanced Boot Options), then press down arrow once (to select Safe Mode) and hit ENTER.
See if this will help.
For Safe Mode with Networking press down arrow twice and hit ENTER.
You an also try booting with Linux Mint MATE DVD (DVD should be 1st boot option by default), don't create bootable USB as it would require to change boot order which you can't see. Then copy paste your files.
AMD Phenom 2 1090T
3xAcer GD245HQ
HighPower 1000W
Noctua NH-D14
Logitech G19
Logitech G500
