Sound card sounds no better than integrated motherboard audio?
XGamer95
11:28 AM
Suffolk County, New York
I purchased the Creative Sound Blaster Audigy SE 7.1 Channels 24-bit 96KHz PCI Interface Sound Card, a cheap, $30 card, and was expecting some improvement over my computer's integrated motherboard audio (Dell XPS 420), but I can't really tell the difference between the two. Is it possible for the card not to sound any better than my computer's integrated audio? I'm using the Logitech Z523 2.1 speaker system.
Sound card: Newegg.com - Creative Sound Blaster Audigy SE 7.1 Channels 24-bit 96KHz PCI Interface Sound Card
Speakers: Newegg.com - Logitech Z523 40 Watts RMS 2.1 Speaker System
Windows 7 Ultimate 64-bitIntel Core i5-3570k @ 3.4GHz (OC to 4.0 GHz T...ADATA XPG Gaming Series 8GB DDR3 1600MHz (2x4GB)2x EVGA GTX 770 2GB Superclocked w/ ACX Cooling
Intel Core i5-3570k @ 3.4GHz (OC to 4.0 GHz Turbo Boost)
MSI Z77A-G45 LGA 1155 Intel Z77 ATX
On Board
1x ASUS VG248QE 24" 144Hz 1ms LED-LCD 3D Ready
1x Corsair Force Series 3 90GB SATA III SSD (OS);
1x Kingston SSDNow V300 Series 120GB SATA III SSD;
1x Hitachi DS7SAC100 1TB 7200 RPM 32MB Cache SATA II HDD;
1x Hitachi DT01ACA300 3TB 7200 RPM 64MB Cache SATA III HDD
EVGA Supernova 1000 P2 1000W Fully Modular Platinum Rated
Rosewill Thor V2 White Full Tower
CM Hyper 212 EVO (Push); 2x Intake 2x Exhaust Fans
Tt eSports Poseidon Cherry MX Brown Mechanical Keyboard
A4Tech X7 F5 Wired Laser Mouse
120 Mbps down, 40 Mbps up
MSE, Malwarebyte's Anti-Malware Premium
ASUS RT-N66U Dual-band N900 Gigabit Router;
Netgear WNDA4100 Dual-band N900 USB Adapter
yes it's possible.
Windows 7 Ultimate 64bitIntel i7 3770K16GB DDR3 1333 Corsair XMS3XFX HD6950 2GB EyeFinity
HAL-9000
Intel i7 3770K
Asus Sabertooth Z77
Logitech G35 & Sennheiser PC135 & VIA HD
23" HP 2310e, 23" Samsung B2230, 21.5" Viewsonic
5760x1080
16TB of Storage
128GB & 256GB Crucial M4 SSD's, 2X 1TB WD Black, 3x 2TB WD, 3x 2TB Samsung F4, 1.5TB Seagate, WD 500GB,
Antec True Power New 650watt
Cooler Master HAF-932
Corsair H60 Hydro Cooler, 3x 230mm Fans, 2x120mm Fan
Logitech G15 and G13
Logitech G700 Gaming Mouse
50/10 Mbit
Speakers : Alesis M1 Active Mk2 Studio Monitors , APC RS 1200 UPS, HP 4500DN Color Laser, HP P1006 mono Laser, Kodak 8500 Dye-Sub, Epson 1280 inkjet, Epson Worforce 610 MFC
You may try adjusting some of the cards settings to see if it helps.
Im not sure about that exact card but ...
I have the Xi-Fi Extreme Gamer and Klipsch Pro Media Speakers.
The difference between the sound card, and onboard audio is huge.
Theres just no comparison.
My onboard sounds muddy & dull in comparision.
A large portion of the sound quality will be from how well the speakers can reproduce the audio. Not that those are bad, I've never heard them.
So if adjusting the sound cards setting does nothing to improve it, its possible it could be that particular sound card, the speakers themselves, or a combination of both.
It is probably fair to say, some modern onboard sound these days is just as good or better than the cheaper sound cards.
Windows 7 Home Premium 64bitIntel Core i7 2700k8GB Mushkin Redline Ridgebacks @1866EVGA GTX570 SC
Custom (Self Build)
Intel Core i7 2700k
eVGA P67 SLI
EVGA GTX570 SC
XiFi Titanium HD
LG W2453V
Seasonic x750
Corsair 600T SE White
eVGA Superclocked CPU Cooler
Saitek Cyborg
Kaspersky
IE
LG BD/DVD
