Solved Sound Problem after installing DAC Question?.
bluesjunior
3:13 AM
I bought a small DAC in order to use my vintage technics analogue stereo system for audio playback from my Win7 PC. I fitted it together via the toslink connection on the PC to the DAC input and then out via RCA connector cable to the AUX output on my amplifier. It works perfectly and I now get really good hi-fi quality sound output. The problem I am asking about is not about the DAC connection which works fine but, when I click on any folder on my hard drive eg to change music or just generally opening a folder I get this pop sound through the speakers. It is similar to the sound you get when connecting a jack plug to a live amplifier. Perhaps this has always been there but my 5.1 digital sound system wasn't affected so much as the full range studio monitors I am now using are. I realise this must be something to do with the Windows OS sounds but don't know if it is possible to turn them off or indeed if it is even advisable to turn them off. Has anyone experienced this and is there a solution?.
Windows 7 Home Premium 64bit SP1
AMD Athlon II X3 450
Gigabyte GA-MA770T-UD3
8.00GB Dual Channel DDR3
Radeon HD 5750
465GB SAMSUNG HD502HJ SATA Disk Device
931GB BUFFALO External HDD USB Device
Comodo CIS
Pale Moon 64bit
I use my PC for my home recording studio so I have all system sounds set to "none". I can't have some Windows function interfere with recording.
Go to the Control Panel/Hardware and Sound and finally the Sound Panel. Click on the Tab for Sound.
See mine, below:
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
See mine, below:
Thank you for a solution Fireberd. By the way I am also from Inverness but the original Scottish version very different weather from the Florida one I suppose. LOL.:D
Radeon HD 5750
Comodo CIS
Pale Moon 64bit
I get the "Inverness" thing every once in a while. Inverness Florida is a small town, on the Florida west coast (about 65 miles north of Tampa).
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
