Sound setting problem.. please help
Kaffei4Lunch
12:32 AM
Hey everyone, I'm new so I hope I'm posting in the correct section.
Anyways, I'm trying to record sound that I can hear from my speakers but apparently I have to enable something:
The blue arrow indicates where I'm supposed to click, but it's grey and I can't click it. If anyone could tell me how to make it so that it's clickable I'd really appreciate it!
PC Dell?
It's under Playback devices and is usually called "stereo mix", instead of a single recording device it records the output of any audio played through the system.
If you don't see it, try right clicking anywhere in the center of the playback device window and enable "show disabled/disconnected devices".
Ap
Assembled in my workshop
Windows 7 Home Premium
Intel Core 2 Duo @ 3.00gHz
Gigabyte GA-P35-S3G
ATI Radeon HD 2600 XT
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
the realtek mic is already default thats why the green check and you cant click the green check indicates your default device what are you recording from you hear it from your speakers shouldnt there be a line in connect instead of mic I mean whats the source and what is it plugged into and yeah right click in the blank area and make sure all devices are showing up
Custom built super system & Fujitsu Lifebook (Lap)
Win7 Ultimate (32) & Win7 Pro (64)
i7-860 (2.8 Ghz Overclocked) & intel centrino duo
Asus P7P55D & standard fujitsu
4 GB (Patriot) & 2 GB
nivida GeForce GTS 250 & standard
Creative Sound Blaster X-Fi Xtreme Audio & default fujitsu
View Sonic , Samsung
1 TB Caviar Black
1 TB Caviar Green
1/2 TB WD (my book thing)
60 gig Hitachi Travel star in the fuji lifebook
(I administer multiple systems but these are mine and usually they are not the ones with problems ---because theyre mine)
THERMALTAKE Toughpower 750 & Standard
Cooler Master Sniper
Standard
