Sound stops when changing audio input problem
borris
7:05 PM
Hello,
I have a standard 3.5mm output jack on the back of my motherboard,
whenever I change the jack, e.g. take speakers out, plug headphones in, the sound stops, usually when i'm using itunes, or bbc iplayer. Sometimes this can crash microsoft messenger as well.
I have to restart the application for the sound to work again.
In the sound options i have the box unchecked for allow applications to take control of this hardware. Also installed latest motherboard driver and problem still exists. Motherboard is Asus P5Q Deluxe.
Can anyone advise?
I had a similar problem on my laptop and rolling back the sound drivers fixed the issue. What happens if you allow applications to take control of the hardware?
Samsung NP305E5A-A03US
AMD A6-3420M APU
4 GB DDR3
AMD Radeon HD 6520G
15.6 LED
1366x768
500 GB hard drive
37mb down, 18mb up, Fios
