sound volume control problem in WMC
htpc
7:42 PM
Hi, I have only one small problem with the sound volume control in WMC. I have a new HTPC, pumpimg sound out via a Digital coax cable to Logitec z5500 speakers. This works just fine, sounds great etc, except..... The sound volume control in WMC doe not work when watching Live TV, or TV accessed from the Guide. In every other WMC circumstance, whether music, recordedtv, videos, slide shows and normal PC noises etc, the sound volume control works just fine. Any ideas???
ThermalTake DH101
p5ql pro (asus)
4gb
None
Plasma tv (hdmi connection)
1 TERRABYTE
In order to control the volume from the PC when using spdif digital output, go to the Control Panel | Sound applet and double click the spdif output device.
Go to the Advanced tab, and uncheck the two Exclusive Mode checkboxes.
Selfbuilt
Windows 7 Ultimate 64bit
i7 2600k
asus P8Z68-V LE
16GB (4x4) corsair vengeance
Intel HD3000 iGPU / AMD HD6870 1024MB
bitstreamed to an Onkyo 609
Asus VE278 27" LED / Bravia EX7 60" LED
native 1080p x2
4x 2TB int. + 2x 2TB external and a SSD for the boot drive.
650w Antec
NZXT tempest evo
air/stock
logitech m505
dual: cable/blackberry tether for travel use
BD re-writer //
asus notebook G73Jw
Shark007, beautiful, this worked out great!
ThermalTake DH101
p5ql pro (asus)
4gb
None
1 TERRABYTE
when you do this, you loose 5.1 dolby surround and all you get is stereo
