Stereo Audio Output Inverted on Realtek Front Panel and Firewire Card
Bungee18
Love Removal Machine
Power User
9:12 PM
Buenos Aires, Argentina
I just realized that stereo output is inverted (L&R are swapped) on my Realtek front panel headphones connector and on my M-Audio Firewire card. Output is OK on Realtek rear main/front speakers connector.
Any ideas on how to fix this?
Thanks,
J
Windows 7 Ultimate x64 SP1AMD FX 8320 4.8GHz, 1.475V4 x GSkill Ripjaws Z 4GB 1600 CL82 x ASUS HD7870 2GB DirectCu II
Custom built
ASUS Crosshair V Formula-Z
M-Audio Firewire 410
2 x Samsung Syncmaster SA300
1600x900
1 x Seagate Barracuda 2TB, 7200 rpm, 64 mb cache - Kingston HyperX 3K 120GB (OS) - Corsair FORCE Series 180GB (Games & Apps)
Corsair TX850M
NZXT Switch 810
Custom Water. XSPC Raystorm, Laing DDC 3.2T PWM, 360+120 rad
Corsair Vengeance 650
Elephant Leviathan 3200 DPI
Too slow
The front panel Headphone switch could just be a wiring error in the front panel, since it is correct at the rear panel. Or the cable that connects the front panel to the motherboard has a wiring error (assuming the connector is properly connected). Many cases have two audio connectors for the front panel, HD Audio and AC97 audio. The HD Audio is the preferred, if you are not using that, connect it and see if that helps. If you have HD Audio connected, and you have AC97, use that.
The MAudio device is a separate issue. I have a Sonar X2 recording studio and have an MAudio Fastrack Ultra 8R interface unit (and a Roland Octa-Capture). I used to have a firewire unit, a Focusrite Saffire Pro 40 and any channel swapping was done in the DAW program (e.g. Sonar).
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
