still need help Power dvd error 1334 and error 1603
tz frantic
8:43 PM
i need help i am trying to install powerdvd9 and a error message comes up error 1334 the file cannot be installed
data.cab is missing and i download it off the official website and then is followed by an error message 1603 fatal error
PACKARD bell
windows 7
4 CPU by Intel Core 2 Quad Q6600
Vegas 2 Motherboard Full ATX motherboard
3 gb ram
NVIDIA GeForce 8800
500GB C D =500GB
Seagate Barracuda 7200.10 500 GB Hard Disk by 2
8 in 1 Gigabyte GO-C81LA CardReader/Writer
OK TZ, now you will need to provide more data. Can you fill in your system specs with more details?
Also, just some advice: if you use a few commas and periods, people will be more willing to help, just because it makes it so much easier to understand what you mean
In the meantime, this page can give you some hints what to look for: Q111019: Error 1603: Fatal Error During Installation
Wally, Innc.
Windows 7 x64 finally!
AMD Athlon II X2 240
Biostar TA790GX XE
OCZ Platinum 4GB DDR2 1066 (will not work past 800MHz)
MSI R4670-MD1G Radeon HD 4670 1GB 128-bit GDDR3
ATI High Definition Audio Device Realtek ALC888
HP w19e
Western Digital Caviar Green WD5000AADS 500GB SATA
Western Digital Caviar Blue WD5000AAKS 500GB SATA
Athena Power Micro ATX 400W
HEC 6T 6T10BB Black MicroATX Mini Tower
stock
wired, many keys
HP wireless, 2 buttons, 1 wheel
DSL 2Mb (recently getting 1.65M!)
ok filled out iit worked before but unistalled it and now will not install
PACKARD bell
windows 7
3 gb ram
NVIDIA GeForce 8800
500GB C D =500GB
Wally, Innc.
Biostar TA790GX XE
HP w19e
stock
wired, many keys
yes but i download it several times
PACKARD bell
windows 7
3 gb ram
NVIDIA GeForce 8800
500GB C D =500GB
Maybe ask Cyberlink for the file's checksum so you can check if your download is OK? Or order the Box version.
Wally, Innc.
Biostar TA790GX XE
HP w19e
stock
wired, many keys
here is the problem
in full detail as i install it error 1334 comes up first and second when it rolls
back action error 1603 comes up
PACKARD bell
windows 7
3 gb ram
NVIDIA GeForce 8800
500GB C D =500GB
I notice you are running kaspersky AV, Maybe its causing an issue with the download or the install.
Self Build
Vista Business x64
AMD Phenom II x3 720be @3.15ghz
Asus M4A77D
2x2GB A-Data DDR2 pc6400
Nvidia EVGA 8800gts (640MB,320bit)
Creative Sound Blaster
Samsung 226bw
Seagate 320gig, WD 80gig
Rosewill 500watt
Dynex
Thermaltake V1
G15
Razor DeathAdder
10.0Mb/896Kb
tryed that no luck
PACKARD bell
windows 7
3 gb ram
NVIDIA GeForce 8800
500GB C D =500GB
I think you will have to contact Cyberlink and ask them for support. Or maybe try installing from the DVD.
Wally, Innc.
Biostar TA790GX XE
HP w19e
stock
wired, many keys
it is a trial version so i did not get dvd
PACKARD bell
windows 7
3 gb ram
NVIDIA GeForce 8800
500GB C D =500GB
