Solved Strange audio problem occuring
harleynut97
12:23 AM
(solved) Strange audio problem occuring
This is a strange one, and will require a longer post ... so sorry in advance.
For some very strange reason all of a sudden I have no audio on any Youtube video, video plays fine.. BUT I do have audio if I watch a vimeo video, or anyother video not hosted by Youtube.
I do have some clues as to what might have led up to the problem.
-I went to do updates on my motherboard MSI
-I downloaded and installed their live update utility
-then let it scan my computer... it told me I had a number of updates... two of them had to do with my onboard sound on the motherboard.
-I downloaded and installed those.... tested the audio ... everything worked fine, including YT
but
-After getting annoying permission messages from this motherboard live update utility I decided to uninstall the utility.
-That is when the YT problem started.
-So I reinstalled the utility again... rescanned.... but this time it only showed 1 of the two updates it originally showed. I installed the one audio update.
I wouldn't think that by uninstalling this utility, it would also uninstall the updates it made, but it appears that it did.
So with that long story in mind, what should I do? I've already tried to have the utility update again, but it did not fix the problem.
Any suggestions would be greatly appreciated.
SYX SG-103
Windows 7 home premium 64 bit sp1
Intel Core I7-2600 3.4 Ghz 1155 8M 95W CPU
MSI P67A-C43 (B3) ATX
16 gb DD3 1333MHZ
Nvidea Gforce GTX 550Ti
Realtek ALC892 integrated
acer 23"
Hitachi 1 TB 3.5" SATA 3G 7200rpm
Seagate ST32000641AS baracuda XT , 2 TB 3.5" 7200 rpm
Western digital My Book 1 tb USB2 external
Western digital My Book 3 tb USB3 external
500 Watt 80 plus
Cooler Master Elite 310 RC-310-BWN1-GP
Logitech MK 200 Keybard
Logitech MK200 mouse
24x DVDRW Dual Layer SATA optical drive
Youtube use Flash player. Reinstall the Adobe Flash and see if that corrects it.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Hey Fireberd, I took your advice and reinstalled flash.... no success I'm afraid. I did not mention in the original post
that I also tried on 2 different browsers, IE and my standard on firefox.
I'm just really scratching my head on this one... not sure what else I should try
SYX SG-103
16 gb DD3 1333MHZ
acer 23"
500 Watt 80 plus
The flash player is the usual fix for no audio, since it apparently works OK otherwise.
Not knowing what you updated with the MSI utility, there may be some other issue, but?? The only other thing I can think of is to use System Restore and restore back to before you first installed the Utility and see what happens. System Restore has an Undo feature if it doesn't help.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
The sage continues :)
After my last post, I thought that I should also check google chrome to see if they YT videos played the audio on that. It didn't at first...
So I uninstalled, and reinstalled google chrome.... upon reinstal,l now the audio plays on google chome!
But it still does NOT play on firefox or explorer.
Let me ask a questions on the recommendation on restore settings..
-Last night I did that.... or tried... I actually created a restore point before doing the original motherboard updates. So I went to do a system restore .... and it locked up during system restore( I've never had that happen) ... now I did not do this in safe mode... I guess that would my next step. If I do choose to do a restore... should I use something either farther back or try that one that failed again in safe mode?
-I've been working on a very time intensive 3d project for work. Is there anychance I would lose any of my work to date using the system restore?
-If there is anything else you can think to try before a system restore, I would appreciate it, especially based on this new update regarding google chrome.
edit: Oh yea... after the google chrome install, I did do a reinstall on firefox... but the problem continues on firefox
SYX SG-103
16 gb DD3 1333MHZ
acer 23"
500 Watt 80 plus
System Restore does not (not supposed to) delete any user data or e-mails.
Completely uninstall/remove flash from both I.E. and Firefox. Then try a new install on each one and see what happens.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Completely uninstall it from both, I.E. and Firefox, restart the PC and then install on one of the browsers and see what happens.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Well I did what you suggested.... and even more
1) uninstalled using adobe uninstaller than did a clean install of flash (newest version) I did this in both Firefox and IE .... no success Google chrome continues to play audio on YT videos. firefox, IE does not.
2) I then tried to revert back to 11.7 archived version of flash... using uninstaller first, the reinstall archived version.... no success. Same situation chrome plays YT audio... others do not.
3) What I have not tried yet is completely uninstalling firefox and reinstalling. I just did the uninstall/reinstall on the flash player. I don't think you can even uninstall IE if I remember right.
Maybe I need to post this part in a different section, but maybe you know...
Prior to doing all of the above. I went back into safe mode and tried to again do a system restore... on the most recent checkpoint I had before doing the Mother board updates. (this is the same one I tried last night that failed or locked up. But again even in safe mode. It seems to lock up never getting past the screen that says "please wait system restore is initializing"
-What would your best guess be that the "initialzing" screen should stay up for before moving on to some type of progress screen? (again this is the first screen that shows up.) I let it set there like that for about a half hour. Than just did a hard shut down. I do have a lot of data and programs on my computer.
-I haven't yet tried to do a different checkpoint even before the one I have been trying.
SYX SG-103
16 gb DD3 1333MHZ
acer 23"
500 Watt 80 plus
This is not really an audio problem. Its more something to do with flash and other software. Probably posting in another forum section would be best.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
OH goodness.... I am so embarassed. Please disregard the post above now, it is solved. But allow me to give you a good chuckle at my expense. After all of this (what turns out to be needless troubleshooting) a friend reminded me to look at the actual videos mute button. Sure enough for some reason, I saw it "X'd" HOW DID I MISS THAT?
He told me adobe flash video remembers the last settings used. What through me off I guess is the videos were playing fine when I checked Google chrome. But it makes sense, when I learned that google chrome uses a different version of flash, and I never use google chrome, so I would have never muted that button for any reason. Believe me I checked all my speaker settings, used the tests for the soundcard, and did all the ridiculous troubleshooting noted above and more.... stupid me!
SYX SG-103
16 gb DD3 1333MHZ
acer 23"
500 Watt 80 plus
Not a problem, at least the problem got resolved. That is the main thing.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
