Solved strange VGA cable problem
proudtobegreek
constantly learning
Power User
10:04 AM
Thessaloniki
I set up an old lying around P4 3.0 Ghz,integrated graphics,hooked up two gigs of RAM,installed a 32 bit 7 copy,checked on my monitor,it worked smooth,nothing spectacular,it worked.Thought to give it as a present to my girlfriend (still on xp) hooked it up,on HER almost identical monitor(19")and i cant get any decent resolution,nothing above 1200xwhatever,stretched screen,blurry letters,a total failure.Tried almost everything,clear type,refresh rate,custom size letters and fonts,tried four different vga cables.Graphics work(1360x...) ONLY with MY cable.Its really a simple,not heavily shielded one,is that what i should look up for?Anything special to watch out for?
Homebuilt,Quadcore processor on Asus MB
Microsoft Windows 7 Ultimate 64-bit Service Pack 1
Intel(R) Core(TM)2 Quad Q 9550 @ 2.83 GHz
ASUS P5B-Deluxe Wi-Fi Edition
4x1024 GB DDR2 Corsair PC2-6400 800 Mhz
MSI TwiFrozer II 1024MB GDDR5
Realtek ALC883 @ Intel 82801HB ICH8 - High Def
Asus VW195 [19" LCD]
1440x860 pixels
OCZ Vertex Plus Series SATA II 2.5" SSD 128GB-
Westarn Digital SATA II 250GB
Corsair CX600W
Custom built,cut and painted
Xigmatek Gaia 2x120mm fan
MS Generic
MS Optical 6000
never enough
ESET Smart Security 6.0.306.0
So you are saying that when you swap cables you have more resolutions available?
Windows 7 professional X64
AMD A10-5800K OC@ 4.4Ghz.
Gigabyte F2A85X-UP4
8GB Kingston HyperX Blu 1333mhz
XFX HD7870 2GB Core Edition
Acer AL2216W
Seagate Barracuda 500gb 7200rpm
Seagate Barracuda 1.5TB 7200rpm
Cooler Master Silent Pro M 850W
Thermaltake Commander MS-I
Cooler Master N520
Logitech M504
10Mbps
Exactly,all four heavily shielded HD vga cables,will not,and do not support acceptable resolutions for a 19 inch monitor,1360x or 1440x something,not even as an option,they give higher or lower ones but it doesnt work that way.My thin,poor shielded does gives her-us a resolution of 1360x which is totally accepted.I am using that thin one on my machine at the moment at a 1440x900 resolution,but i am on a graphics card.
1440x860 pixels
Corsair CX600W
MS Generic
MS Optical 6000
never enough
Gigabyte F2A85X-UP4
Acer AL2216W
Cooler Master N520
Logitech M504
10Mbps
Thats easy to say,i have visited half of this towns computer shops,cant offer me more than a standard thick vga cable that only states 80'C 30 V low voltage computer,nothing specific like your definitions.I am sure it has got to do with them hard shieldings,i am looking for another thin one,that onboard card is sending low graphic signal if that term exists,it s only my thought.
1440x860 pixels
Corsair CX600W
MS Generic
MS Optical 6000
never enough
I beleive it has a lot more to do with a cheap cable and an ''average'' priced cable.
I have all sort of cable gauges for VGA and they all have the same resolution capabilities.
Gigabyte F2A85X-UP4
Acer AL2216W
Cooler Master N520
Logitech M504
10Mbps
Its not about the price,i am referring to the signal's output,it must be low so the shielded one wont let it go to the monitors end and be fully recognized,although its a 1.8 m long one.I am not really good at these technical terms,its only my thinking out loud.The only common (or different) thing that those cables have is their shielding capability.
1440x860 pixels
Corsair CX600W
MS Generic
MS Optical 6000
never enough
Is the monitor correctly identified by both cables? I do believe some of the pins/wires are used by the PC to ID the make and model of monitor connected. If its showing up a generic that may explain the improper resolution settings. Have you tried the "Advanced settings" option that is listed on the Screen resolution window. If you click that there is a "list all modes" option in the window that opens. That should list all the modes supported by the video card regardless of the monitor connected.
Home Built
Windows 10 Education 64 bit
Thermaltake TR 620
Stock heatsink and fan
Logitech Wireless K350 Wave
80 Mbps Down 30 Mbps Up
Windows Defender
Internet Explorer 11
Under advanced settings,monitor tab,general tab it shows up as generic,standard monitor types on Intel tech etc,changing refresh rates to 60,75 or 90 doesnt help at all,lowered to 16 bit colors,nothing.When connected via the thin cable,same statements,only two rates (60 and 75) which both are functional.Monitor shows up in device manager,un- and reinstalled,no ergo.
1440x860 pixels
Corsair CX600W
MS Generic
MS Optical 6000
never enough
Did it!After searching several pc shops,finally got a thin one,plugged it in and 1366x768 resolution auto detected as recommended.I will skip the technical explanation,wouldnt be able even if i wanted to!Thanks to everybody for your thoughts and inputs,marking as solved.
1440x860 pixels
Corsair CX600W
MS Generic
MS Optical 6000
never enough
