Sudden Network Connection Problems, Very Weak Signal or Won't Connect
barnettkvb
9:05 AM
My wifi has suddenly stopped connecting to my laptop. It works perfectly on my phone and other computers, so I know it's not the router. I've renewed my IP address, uninstalled and reinstalled all the correct drivers, double checked my network settings, restarted my computer in safe mode with networking (which didn't help at all), run Windows Update, run troubleshooter (which just told me it couldn't solve the problem), and I've reset my computer to an earlier point before the problem started but I still can't connect. I can connect through the ethernet cord and then if I sit right by the router I'm fine but more than 20 feet and my signal is completely gone. Please help :(
Windows 7 Home Premium 64bitIntel Premium CPU B960 @ 2.2GHz
Acer Aspire 5749Z
Welcome to the forum please download www.crewetown.co.uk/wireless.exe right click choose run as admin post results
Okay thank you, I ran it and ended up with this:
Windows IP Configuration
Host Name . . . . . . . . . . . . : Kelsie-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : Home
Wireless LAN adapter Wireless Network Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter
Physical Address. . . . . . . . . : 1E-E9-D3-1A-CC-7E
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : Home
Description . . . . . . . . . . . : Atheros AR5B125 Wireless Network Adapter
Physical Address. . . . . . . . . : 7C-E9-D3-1A-CC-7E
Link-local IPv6 Address . . . . . : fe80::a9e2:b87e:be50:54a0%16(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.16(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, January 17, 2017 2:14:27 PM
Lease Expires . . . . . . . . . . : Wednesday, January 18, 2017 3:39:29 PM
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 226290131
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1B-4C-A7-52-04-7D-7B-25-65-F4
DNS Servers . . . . . . . . . . . : 192.168.1.254
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Atheros AR8152/8158 PCI-E Fast Ethernet Controller
Physical Address. . . . . . . . . : 04-7D-7B-25-65-F4
Tunnel adapter isatap.{DC9C0CD3-E4FB-465A-822D-763B51706F96}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Tunnel adapter isatap.Home:
Acer Aspire 5749Z
Something you can try is changing the wifi channel.. sometimes if too many networks are broadcasting the same signal you wont be able to connect or will continue to keep getting bumped off.
Windows 7 Ultimate x64Pentium D 3.0 ghz overclocked to 3.7ghzDDR2 8gb - CorsairXFX Radeon HD 4350 1gb
Dell XPS Gen 5
Dell 0gc068
DDR2 8gb - Corsair
Creative SB X-Fi
Dell 2007FP
1600 x 1200
seagate and western digital
Dell XPS Gen 5
Razer DeathStalker
Razer Deathadder
AVG 2013 Pro
Firefox,IE10,Chrome
You only posted 50% of the report did you right click and choose run as administrator it should show any routers in your area with channels
win 8 32 bit
win 8 32 bit
Sorry, I ran it again, is this all the information? It was too big to copy and paste so I attached the .txt file
Acer Aspire 5749Z
There is another router on the same channel as you with similar strength which will kill your connection your signal strength is very low so you will struggle anyway. Go onto router and change to channel one. Look at what you have running at start as you have a lot starting
win 8 32 bit
win 8 32 bit
I've successfully changed the channel on the router to one not being used and disabled all the extra startup programs, but still weak or no signal. How can I tell if this is a hardware problem or not?
Acer Aspire 5749Z
If you get next to the router do you get 100% can you get anothe rpc or tabley in the same location does that get a better signal
win 8 32 bit
win 8 32 bit
yes, I can get a five bar signal if I put the laptop right next to the router, but the signal dissolves if I move it more than ten feet away. I have my laptop and a tablet in the same room right now and the tablet gets perfect internet, but the laptop can't pick up a signal at all
Acer Aspire 5749Z
