System Freezes, Kernel Power Error
We will await your confirmation that all is well again.
LAPTOP. HP Pavilion dv7-4010TX .
Win 7 Ultimate 64-bit. SP1.
Intel i7 -720QM.[1.6GHz Turbo Boost 2.8GHz. 6MB Cache.]
8 DDR 3 RAM. 1066MHZ
ATI 1024 MB. DDR3. Radeon HD5650
17.3" High Definition Brightview LCD. LED Backlit.
1600 x 900.
640GB
Laptop / notebook.
Logitech Anywhere mouse. MX.
ADSL [ but too slow ]
The computer ran great this morning, until about an hour ago when I noticed it was frozen at the log on screen. Tried everything to get it to respond. nothing. I turned it off by the power button, and thought I would try the memtest again.
Start the memtest86 and come back to the computer about an hour later to find this:
Im not sure if memtest stops when it finds errors or if the system froze, because it was stopped at 44% and not going anywhere.
Do I have to start pulling ram or can you guys diagnose it somewhat with that screen shot?
HP
You have to start pullng ram. Run memtest with each individual stick to find the bad ones
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
So run it with one stick at a time? Does it matter which slot its in?
HP
Kyle
start with one known good stick and test in each mobo slot. It should pass.
All this is specified in the memtest instructions.
These crashes were caused by memory corruption. Please run these two tests to verify your memory and find which driver is causing the problem.
1-Memtest.
*Download a copy of Memtest86 and burn the ISO to a CD using Iso Recorder or another ISO burning program. http://www.memtest.org/#downiso
*Boot from the CD, and leave it running for at least 5 or 6 passes.
Just remember, any time Memtest reports errors, it can be either bad RAM or a bad motherboard slot.
Test the sticks individually, and if you find a good one, test it in all slots.
Any errors are indicative of a memory problem.
If a known good stick fails in a motherboard slot it is probably the slot.
http://www.sevenforums.com/tutorials/105647-ram-test-memtest86.html
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
When I opened up the machine I found one of my ram sticks not fully locked in the slot.
Thinking that was hopefully the problem, I snapped it in all the way. Plugged the computer back in and ran memtest86. It made one clean pass so I restarted the computer.(I know you're supposed to run multiple passes, but I thought this loose ram was the problem)
But later last night it froze up on me again. and a couple hours later I came back to see it frozen at the log on screen again.
Im really not sure what it is now, Im going to try and run memtest86 and let it do a couple passes.
HP
Just finished the memtest. I ran each stick in a different slot. I let it make 3 passes for each stick. Came back with 0 errors. I will see if the problem persists.
HP
Good luck and let us know
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
Froze on me again. :(
Its only logged one file in the minidump since Ive reinstalled windows.
HP
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: 124
BCP1: 0000000000000000
BCP2: FFFFFA80071D88F8
BCP3: 0000000000000000
BCP4: 0000000000000000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\111811-37315-01.dmp
C:\Users\Kyle\AppData\Local\Temp\WER-68921-0.sysdata.xml
Ive attatched to two files that are in bold, hopefully that may help you guys somewhat.
HP
Ive been trying to find updates and finally found one for my chipset. It hasnt froze all day, but just did now and the screen was doing this when it was frozen.
HP
Why isnt anybody replying to this anymore? :(
HP
