system kernel power event 41 help
jeb007
3:35 AM
BSOD help pls
Hi, I would kindly ask if anyone could help me with this event log. My BSOD event only seems to occur when i am using fsx and it it happens randomly. Im on windows 7 64 bit and this has been baffling me for a while any help would be great many thanks.
pc specialist custom build
windows 7 64 bit
intel core2 quad q6600 2.4ghz oc to 3.2gh
asus p5k se/epu
4 g ram ddr2
xfx nvidia geforce GTX 260 black edition with zalamanheatsin
none
hannspree 19"
750wtt
10mb
Is there anyone who could help pls?
windows 7 64 bit
asus p5k se/epu
4 g ram ddr2
none
hannspree 19"
750wtt
10mb
Looking at your minidumps now...
Barebones
AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz
MSI NF980-G65 AM3 NVIDIA nForce 980a SLI
G.SKILL Ripjaws Series 8GB (4 x 2GB) DDR3 (PC3 12800)
SLI GeForce GTX 480 (Fermi) 1536MB 384-bit GDDR5
onboard
Toshiba TV 42'' or 27.5'' widescreen monitor
1920x1080 60hz
2x SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/
Antec TPQ-1200 1200W Continuous Power with PowerCache
COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full To
1 x 140mm rear fan, 3x 230mm Fans (front, top, side)
Logitech G15
Logitech MX 518
13 mb/s down 5.5 mb/s up
Main system.. other system is slightly different
Hello !! Welcome to SF !!
Seems like some Hardware has caused the crash. Check this article http://www.sevenforums.com/crash-lockup-debug-how/35349-2-int-stop-0x124-what-means-what-try.html
Bugcheck:
[FONT=Book Antiqua][COLOR=Navy]Built by: 7600.16539.amd64fre.win7_gdr.100226-1909
Debug session time: Tue Jun 29 20:47:14.878 2010 (GMT+5)
System Uptime: 0 days 0:40:34.923
BUGCHECK_STR:  0x124_GenuineIntel
PROCESS_NAME:  fsx.exe[/COLOR][/FONT]
Out-dated Drivers:
[COLOR=Navy]rp_skt64.sys Thu Nov 27 01:45:20 2008
rp_pkt64.sys Fri Apr 06 00:21:01 2007
nvoclk64.sys Wed Sep 05 07:56:33 2007[/COLOR]
Captain
Samsung NP550P5C-S02IN
Intel® Core™ i7 Processor 3,610QM (2.30Hz, 6MB L3 Cach
8 GB
NVIDIA® GeForce® GT 650M 2GB Graphics, Optimus™ techno
SoundAlive™ JBL 3 Speakers (With sub-Woofer)
39.62cm (15.6) SuperBright 300nit HD+ LED Display
1,600 x 900, Anti-Reflective
1TB S-ATA II Hard Drive (5,400RPM)
0x00000124    00000000`00000000    fffffa80`04f48028    00000000`b2000040    00000000`00000800    hal.dll    hal.dll+12903
0x00000124    00000000`00000000    fffffa80`04fa8028    00000000`b2000040    00000000`00000800    hal.dll    hal.dll+12903
0x00000124    00000000`00000000    fffffa80`04aa6028    00000000`b2000040    00000000`00000800    hal.dll    hal.dll+12903
 IRQL_NOT_LESS_OR_EQUAL    0x0000000a    00000000`00000028    00000000`00000002    00000000`00000000    fffff800`02c5ccb0    ntoskrnl.exe    ntoskrnl.exe+70600
0x00000124    00000000`00000000    fffffa80`04f1e028    00000000`b2000040    00000000`00000800    hal.dll    hal.dll+12903
0x00000124    00000000`00000000    fffffa80`04f07028    00000000`b2000040    00000000`00000800    hal.dll    hal.dll+12903
0x00000124    00000000`00000000    fffffa80`04ee7028    00000000`b2000040    00000000`00000800    hal.dll    hal.dll+12903
0x00000124    00000000`00000000    fffffa80`04f00028    00000000`b2000040    00000000`00000800    hal.dll    hal.dll+12903
The problem is due to a problem with the motherboard wherein the front side bus - running at full speed - creates a fatal error of some kind and viola! a BSOD. Now the solution is far more trickier. Make sure your motherboard is up-to-date with its drivers.
Barebones
onboard
1920x1080 60hz
Logitech G15
Logitech MX 518
Thank you for taking a look for me and responing. I will check for motherboard drivers and see if this fixes the issue once again many thanks
windows 7 64 bit
asus p5k se/epu
4 g ram ddr2
none
hannspree 19"
750wtt
10mb
