system rebots when i start 3ds max software help!
Samia
10:53 PM
Pakistan
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: 116
BCP1: 8655B510
BCP2: 8E21B9B0
BCP3: 00000000
BCP4: 00000002
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\081711-14742-01.dmp
C:\Users\SAM\AppData\Local\Temp\WER-32307-0.sysdata.xml
Read our privacy statement online:
Windows 7 Privacy Statement - Microsoft Windows
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Core 2duo 2.93GHz
Windows 7 Professional x32
Intel DG41 RQ
500GB
Realtech High definition Audio
Accer V193HQ
Legend
A-4 tech KR-85
A-4 Tech OP-620D (Usb)
1 MB
Problem signature:
Locale ID: 1033
BCCode: 116
BCP1: 8655B510
BCP2: 8E21B9B0
BCP3: 00000000
BCP4: 00000002
Service Pack: 0_0
Product: 256_1
To enable us to assist you with your computer's BSOD symptoms, upload the contents of your "\Windows\Minidump" folder.
The procedure:
* Copy the contents of \Windows\Minidump to another (temporary) location somewhere on your machine.
* Zip up the copy.
* Attach the ZIP archive to your post using the "paperclip" (file attachments) button.
*If the files are too large please upload them to a file sharing service like "Rapidshare" and put a link to them in your reply.
To ensure minidumps are enabled:
Go to Start, in the Search Box type: sysdm.cpl, press Enter.
Under the Advanced tab, click on the Startup and Recovery Settings... button.
Ensure that Automatically restart is unchecked.
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box (the 256kb varies).
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump.
OK your way out.
Reboot if changes have been made.
"It's not a true crash, in the sense that the bluescreen was initiated only because the combination of video driver and video hardware was being unresponsive, and not because of any synchronous processing exception.
Since Vista, the "Timeout Detection and Recovery" (TDR) components of the OS video subsystem have been capable of doing some truly impressive things to try to recover from issues which would have caused earlier OSs like XP to crash.
As a last resort, the TDR subsystem sends the video driver a "please restart yourself now!" command and waits a few seconds.
If there's no response, the OS concludes that the video driver/hardware combo has truly collapsed in a heap, and it fires off that stop 0x116 BSOD.
If playing with video driver versions hasn't helped, make sure the box is not overheating.
Try removing a side panel and aiming a big mains fan straight at the motherboard and GPU.
Run it like that for a few hours or days - long enough to ascertain whether cooler temperatures make a difference.
If so, it might be as simple as dust buildup and subsequently inadequate cooling.
I would download cpu-z and gpu-z (both free) and keep an eye on the video temps Let us know if you need help http://www.sevenforums.com/crash-lo...op-0x116-video_tdr_error-troubleshooting.html
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
STOP 0x116: occured now my system can't even erinstall new windows :( i have done soft image recovery
Core 2duo 2.93GHz
Intel DG41 RQ
500GB
Accer V193HQ
Legend
A-4 tech KR-85
1 MB
i'm using windows 7 ultimate n i couldn't find sysdm. file even from start up nor recovery settings
Core 2duo 2.93GHz
Intel DG41 RQ
500GB
Accer V193HQ
Legend
A-4 tech KR-85
1 MB
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
