Solved System Reset, Not BSOD, When Using Skyrim Creation Kit
Brewskie
1:49 PM
For the past few days my Win7 computer would reset to BIOS. No warnings, just BAM! hard reboot of the computer.
I've unchecked the box under computer/properties that would Automatically Restart the system on crash. So that's just one thing I've tried in order to try to find the issue.
I think this may be a driver issue but I'm not sure. I've installed several iterations of the graphics drivers and other things but the issue remains.
I originally thought it was an issue with certain areas in the Skyrim Creation Kit. It seemed, up until this morning, that one little spot in the editor and the system would reboot, every time. But this morning I was looking at the screen and it reset....my hand wasn't even on the mouse. Like a ghost reached down and hit the reset button on the case. The crashes have not happened unless the Skyrim Creation Kit is running, however, the CK is almost always running anyways.
I'm fairly certain this is a heat related issue because it didn't start until the temps in the house started to rise. However, using "RealTemp", the temperature hovers around 37-40c idle and about 55-60c under load, which is quite good (because of the water cooler probably).
I've posted about this problem on the forums at Bethsoft too: CTD? Naw...Reboot? Yay! - Bethesda Softworks Forums
What I think I need is an app that will create a dump of things like temps etc when the crash occurs.
I've look at the Event Viewer and it shows a generic error about power being lost (Duh! The computer reset lol)
Any help would be greatly appreciated!
My Setup:
Core-I7 2600K @ 4ghz
H60 water cooler (for CPU)
Asus P8P67 Deluxe mainboard
8 GB Corsair Vengeance 1866 (CAS 9) RAM
MSI GTX-580oc Geforce video card
128 GB Crucial RealSSD C300 System drive (SSD) + 3 other drives
1,000w Ultra X3 modular PSU
Windows 7 Pro SP1 64bit
Core i7 2600K
Asus P8P67 Deluxe
Corsair Vengeance 8GB DDR3-1866mhz
MSI Geforce GTX580oc
(boot Drive) Crucial RealSSD C300 CTFDDAC128MAG-1G1CCA (128GB)-
WD Caviar Black 1TB-
2 Seagate 500GB drives
Modular Ultra X3 1000w
CoolerMaster HAF X
Corsair H70 Water Cooler
Logitech G-15
Logitech MX518
6Mb/s
I see your problem was solved with a re-install of DirectX. I wonder if a scan with http://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html would have picked it up.
Regardless, nice work finding the corrupted DirectX. I also agree about clean installing once a year (or even once every six months for some). I just did a clean install this weekend myself, so I can relate to you doing one as a result of the problem you fixed with DirectX.
Download: DirectX SDK - (June 2010) - Microsoft Download Center - Download Details is what you used to re-install?
HP Pavilion e9110t
Windows 7 Home Premium 64 Bit
Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
Pegatron IPIEL-LA3
6.00 GB Hundai HMT125U6BFR8C-H9
ATI Radeon HD 4850
Realtek High Definition Audio/ATI High Definition Audio
Acer AL2216W
Hitachi HDP725050GLA360 ATA Device 500 GB
Unknown/installed by HP
HP generic case
Intel Stock Cooling
HP Keyboard
HP Mouse
Download: 19.15 Mbps Upload: 1.67 Mbps
Network Adapter Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)
Network Adapter 802.11n Wireless PCI Express Card LAN Adapter
