System Unit Case Fans Power Requirments
rapstarrr91
Don†uroN
2:38 AM
Philippines
Processor: Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz
Motherboard: BIOSTAR H81MHV3
RAM: 2x4GB 8GB Kingston Hyper X 1866 OC
Logical Disk: Kingston 120GB SSD
GPU: EVGA GeForce GTX 960 2GB 128bit
PSU: FSP HEXA 550w
I'm planning to hook up six 120mm Case Fans with LED Light.
I don't overclock so the questions is, will my PSU be able to supply enough if i add 6 fans?
Windows 7 x64 Home Premium
Intel® Core i5 3470 (3.20G) 1333fsb 6mb
Foxconn P67A-S Intel® P67 Chipset
(2x4GB) 8GB DDR3 1600MHz Memory
HIS 1GB ATI 6850 Fan HDMI-2xDVI-DP GDDR5 256bit
LED Qube 18.5" Wide Screen w/ DVI
Hitachi 1TB 7200RPM Hard Drive SATA3
Qube 700W PSU
Huntkey H403 ATX-B Chassis
Fans use very little power--a watt or so.
You shouldn't have any problems due to the fans.
I have no idea if your power supply is good, bad, or indifferent, but if it has problems it won't be due to the fans.
Likewise, LEDs of the size you would find on a fan use very little power.
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
Yep your gpu at full load is 400w
Although you don't have a lot of head room on a 550w psu as long as the mobo has that many connection you should be okay the system will adjust to temperature.
Custom assembled by me :}
Win-7-Pro64bit 7-H-Prem-64bit
Built-in Realtek
2-Samsung M.2 Evo & Evo Plus
Custom water loops
FireFox & Pale moon
Thank you for the response. you guys have been very helpful
Qube 700W PSU
