hello everyone
well i have toshiba qosmio x505 q870 with nvidia gts 360m. core i7 q720 @1.6
i have this strange problem .. the laptop freezes recently alot that im not being to use it, it happens not in particular situation .. it may happen in any time in anything you are doing last time happened i was logging in and i wish to know whats the problem .. after freezing i can only do ahard shut down by the power button
i tried mem test .. no errors i have 8gb ram
i tried scanning the hard disk for bad sectors .. also nth i have 128 gb ssd and another 500gb seagate 7200 rpm
i tried replacing rams .. still happening
i used the laptop without battery only on power still happening
used the battery alone also happened
changed the windows copy yes it freezed
some times when it happens i take off the battery take of the rams and keep pressing the power button to reset the laptop thing about electricity thats what the told me . then it will happen but after awhile.
once i did sth i disassembly the laptop eveything out and did acleaning for eveyrhing ( bearing in mind it wasnt full of dust or anything it was clean ) and then reput everything in place that was awhile ago after that it took awhile before re happening about amonth .
and one time happened during the installtion of windows =S
i tried eveything
i updated all the drivers uninstall reinstall i did a recovery i did eveything with no results
no over heating problems
i asked the support center and they didnt figure out whats causing
plz
anyone can help =(
im disperate
i tried eveything
plz
anyone can help =(
im disperate
Microsoft Windows 8 Release Preview 64-bit 84...Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz8.00 GBNVIDIA GeForce GTS 360M (Microsoft Corporatio...
- toshiba qosmio x505 - q 870
- Microsoft Windows 8 Release Preview 64-bit 8400 Multiprocessor Free
- Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz
- Motherboard
- TOSHIBA Qosmio X505
- 8.00 GB
- Graphics Card(s)
- NVIDIA GeForce GTS 360M (Microsoft Corporation - WDDM v1.2)
- Sound Card
- (1) High Definition Audio Device (2) High Definition Audio
- Screen Resolution
- 0 x 0 x 0 bits (0 colors) @ 0 Hz
- Hard Drives
- KINGSTON SV100S2128G
