Twinhan DVB card driver works in Vista 64bit but not 7 64bit HELP HELP
medorpg
1:30 AM
Hello
I have a DVB card called Twinhan 1025
Twinhan company is gone so they dont provide new drivers
the driver we have is for Vista 64bit which works well with RAM more or less than 4 GB but in Windows 7 64bit it works with only RAM less than 4 GB :confused::confused:
My RAM is 6 GB when I boot normally I am able to get the signal level and quality but cant add channels or view them
when I set the boot option the limits the memory to 4000MB I am able to view or add new channels
This is not a software issue
cause I have tried programs in compatibility mode and as administrator
and download viewers for 64bit OS and for 32 bit OS
So it's a driver problem or Windows 7 problem
Now can I do something to make Windows allow this driver to map specific range of memory ?
Please help with any solution cause the workaround of limiting the boot memory isn't a practical one
I even tried to install VM's and install Windows XP but they do not provide access to PCI slots
Windows 7 Ultimate 64bitIntel Core i7 920 @2.676 GB DDR3 1800 MhzATI HD4670
Gigabyte UD3R
6 GB DDR3 1800 Mhz
ATI HD4670
Hec Cougar 700W
SETTO 1000
Up!
Gigabyte UD3R
6 GB DDR3 1800 Mhz
ATI HD4670
Hec Cougar 700W
SETTO 1000
up!
Gigabyte UD3R
6 GB DDR3 1800 Mhz
ATI HD4670
Hec Cougar 700W
SETTO 1000
