Two different BSOD's in 2 days, recently upgraded some parts, help!
mobywan420
9:25 PM
Hi there Seven Forums,
first time posting here and very much in need of your expertise in this matter.
I recently upgraded a bunch of hardware in my computer on 7/18/2014. This hardware includes a new video card (msi 770 tf), 2 new hard drives (samsung 128gb ssd and wd black 1tb), and a new power supply
(thermaltake smartm 750w).
After completing the build I re-installed windows and all the drivers and went about my business.
That night I left my computer on throughout the night and woke up to find a windows error saying the computer had shutdown some time during the night because of a bluescreen error. Using bluescreenview I found out that the error had occurred at 7/18/2014 at 9:55am with the bad check string saying 'BAD_POOL_HEADER' and bug check code '0x00000019'.
The second bluescreen was last night or I guess early morning of today 7/20/2014 when I went to shut down the computer it bsod's right before the shutdown completed. Using bluescreenview I got the info bad check string 'PAGE_FAULT_IN_NONPAGED_AREA' and bug check code '0x00000050'.
Attached I've added the zip file from DM Log Collector and hopefully someone can take a look and help me out with this.
I'm desperate to find a solution to this after upgrading all this stuff I don't want to deal with any BSOD's :cry:
Microsoft Windows 7 Ultimate 64-bit 7600 Mult...Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz8.00 GBNVIDIA GeForce GTX 770
Microsoft Windows 7 Ultimate 64-bit 7600 Multiprocessor Free
ASUSTeK COMPUTER INC. P8H77-V
8.00 GB
NVIDIA High Definition Audio
ASUS VS248H-P 24"
(1) Samsung SSD 840 EVO 120G (2) WDC WD1003FZEX-00MK2A0 (3) Hitachi HDS721010CLA332 USB Device
Thermaltake Smart M 750W
Cooler Master HAF
Razer Death Adder
AVG + Malware Bytes
Please can anyone help me with this?
8.00 GB
ASUS VS248H-P 24"
Cooler Master HAF
Razer Death Adder
AVG + Malware Bytes
Bump.
8.00 GB
ASUS VS248H-P 24"
Cooler Master HAF
Razer Death Adder
AVG + Malware Bytes
mobywan420, After your clean install, have you run and installed all Windows Updates? Also, where did you get your Windows 7 from? These are mostly Windows files that never cause BSODs and some come through Windows updates.
BugCheck 19, {20, fffffa800c08f600, fffffa800c08f660, 4060003}
*** WARNING: Unable to verify timestamp for mwac.sys
*** ERROR: Module load completed but symbols could not be loaded for mwac.sys
Probably caused by : [COLOR=red]NETIO.SYS[/COLOR] ( NETIO!NetioDereferenceNetBufferList+86 )
Followup: MachineOwner
2: kd> lmvm NETIO
start             end                 module name
fffff880`01a63000 fffff880`01ac3000   NETIO      (pdb symbols)          c:\symcache\netio.pdb\4ACD68B3A9824AAAB3C53C0077FC611F2\netio.pdb
    Loaded symbol image file: NETIO.SYS
    Mapped memory image file: c:\symcache\NETIO.SYS\4A5BC18A60000\NETIO.SYS
    Image path: \SystemRoot\system32\drivers\NETIO.SYS
    Image name: NETIO.SYS
    Timestamp:        Mon Jul 13 18:21:46 2009 (4A5BC18A)
    CheckSum:         0005F36C
    ImageSize:        00060000
    File version:     6.1.7600.16385
    Product version:  6.1.7600.16385
    File flags:       0 (Mask 3F)
    File OS:          40004 NT Win32
    File type:        3.6 Driver
    File date:        00000000.00000000
    Translations:     0409.04b0
    CompanyName:      Microsoft Corporation
    ProductName:      Microsoft® Windows® Operating System
    InternalName:     netio.sys
    OriginalFilename: netio.sys
    ProductVersion:   6.1.7600.16385
    FileVersion:      6.1.7600.16385 (win7_rtm.090713-1255)
    FileDescription:  Network I/O Subsystem
    LegalCopyright:   © Microsoft Corporation. All rights reserved.
2: kd> lmvm NETIO
    Loaded symbol image file: [COLOR=red]NETIO.SYS[/COLOR]
    CheckSum:         0005F36C
    ImageSize:        00060000
This is your Network I/O system
We would like information in more specific details about your system too
Please fill out your System Specs
Your System Specs will help us to help you, and doing it in this manner will make them available to all helpers in every post and keep us from hunting for them. We ask that you fill them out in as much detail as possible including Desktop or Laptop, Model number if it is an OEM computer and all components with the Manufacturer and Model number if possible.
If you will go to your last post and click the 'System Specs' in the bottom left of the post, you will find a link to update your system specs. Please fill those out in as much detail as possible. If you would like to know what we would like, you can click 'My System Specs' at the bottom left of this post to see mine. If you do not know what your components are, this will help you accomplish this task. http://www.sevenforums.com/tutorials/180324-system-info-see-your-system-specs.html
    ALWAYS UNDER CONSTRUCTION
    Windows 11 Pro
    Ryzen 9 5900X
    Asus X570 Crosshair Viii Hero
    32GB G Skill DDR4-3600
    EVGA RTX 3080 FTW 3 Ultra
    3 X Asus 27"
    2 X 1 TB NVME drives
    EVGA 850
    Phanteks Eclipse P400A
    EVGA 280 AIO
    Logitech G510s/ Logitech G13
    Logitech G502
    ESET/MBAM Pro/SAS Pro
    Chrome/ Firefox/ Edge
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
Hi Essenbe,
thanks so much for responding to my post here!
Yes I installed all the windows updates that were on the list.
I got this copy of Windows 7 from a friend of mine, I hope that is alright.
Also I never mentioned when I was installing windows I was getting some errors with my cd drive not reading the disk properly. Do you think windows could've not installed properly from that? And should I try a fresh install with an external cd drive since the one I was using was fairly old.
Or your saying it's primarily an issue with the windows updates?
I updated my system specs as much as I could, I hope this helps :)
8.00 GB
ASUS VS248H-P 24"
Cooler Master HAF
Razer Death Adder
AVG + Malware Bytes
I hope you didn't pay the friend for this copy of windows because it is an illegal copy. When you have cracked copies, you get issues like this.
Counterfeit installations such as yours contained heavily modified code that causes the installation to behave it unexpected ways. Analyzing BSOD's and determining their causes on these sorts of installations is very unreliable. For this reason, many analysts won't attempt it.
My recommendation is to install a genuine Windows 7. This will minimize the problems you are experiencing, and make subsequent diagnosis of BSOD's far more reliable. Once you are running a genuine Windows 7 installation, and are still experiencing BSOD's, we will be happy to help you solve them
    Windows 11 Pro
    Ryzen 9 5900X
    3 X Asus 27"
    EVGA 850
    EVGA 280 AIO
    Logitech G502
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
OK thank you for your help.
8.00 GB
ASUS VS248H-P 24"
Cooler Master HAF
Razer Death Adder
AVG + Malware Bytes
