Unable to right click-open with "there was a problem starting shimgvw"
Sylveon Fetish
Banned
6:45 AM
I am having an issue opening various file formats in various applications via the right-click "Open With" context menu. Every time I try, I get the following error message:
there was a problem starting C:\Windows\shimgvw.dll
A Dynamic Link Library (DLL) initialization routine failed.
It doesn't matter what file type I right-click on or what program I tell it to open with, that error message occurs every single time.
I Googled the problem but only other unrelated results about shimgvw.dll showed up and all of which are really old, like 2007 and earlier, None of which even mentions Windows 7. There is nothing regarding opening files with right-click menu or Windows 7 and this error message.
Does anybody know what the problem could be and how do I fix this? Thanks
Windows 7 Ultimate 64-bit SP1Intel Core 2 Duo E8400 @ 3.00GHz8.00GB Single-Channel DDR3 @ 531MHz (7-7-7-20)Intel Q45/Q43 Express Chipset (Dell)
Dell Optiplex 780
Dell Inc. 03NVJ6 (CPU)
SoundMAX Integrated Digital High Definition Audio
Viore
149GB Seagate ST3160318AS (SATA)
up to 7 Mbps (average 3.2 Mbps)
AVG IS
Firefox, Chrome
I would run a System File Check (SFC) to see if there are any errors that can or can't be fixed.
You might need to run it up to 3 times to fix errors.
Here is the tutorial:
home built
AMD Athlon II x4 620
Gigabyte GA-MA785G-UD3H
6GB GSkill DDR2 800
AMD 4670 GPU + AMD 4200 IGP
on board Realtek ALC889A
OCZ Vertex 3 120GB,
Samsung F3 1TB (3),
Corsair 500 W
Rosewill mid tower
CM 90mm rifle
Avast, MBAM3, EMET, WinPatrol
Pale Moon, Firefox, IE
2 multi-boot PC's
Trendnet USB KVM.
Doing a search for that .dll, I see many hits relative to full screen view "imgvw" and to Windows Picture and Fax Viewer.
I don't have Win 7 installed right now (its on another PC that is down for parts). But If you go to Control Panel/Programs and finally Turn Windows features on or off, if the Windows Picture and Fax Viewer is listed, turn it off, restart the PC then turn it back on.
If not, try SFC /scannow and see if it finds any corrupted files.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
OEM Windows 7 Ult (x64) SP1Intel Core-i7 3770 @ 3.4 GHz16 GB DDR3 SDRAM @ 1333 MHzNVidia GeForce GT620 1 GB
Dell Studio XPS 8500
"Dell" branded
THX TruStudio PC
Dell U2410 Full HD
2.0 TB SATA2 @ 7200 RPM
350W
MS 4000 Ergon - Wired
Logitech Anywhere MX
Cable HSI w/Turbo (router)
KIS-MBAM Premium-MBAE Premium
Fx (current version); IE
And a Win7/64 Pro laptop; And a Win10/64 Pro desktop.
