USB 3 Running at High-Speed (I'm Going Insane!)
gohan2091
11:24 AM
UK
I have an Asrock Z68 Extreme4 motherboard that has 2 USB 3.0 ports at the rear. My external WD My Book 4TB USB 3.0 Hard drive will not operate at USB 3.0 speeds no matter what I do. Using USB Device Tree Viewer (which actually shows I have 8 USB 3.0 ports....hmmm), it always shows my external HD as "high-speed" using USB Version 2.10 and not "SuperSpeed" using USB version 3.00. I have a 32GB USB memory stick which inside USB Device Tree Viewer, shows it as "SuperSpeed" most of the time but frustratingly, sometimes this will only show as "high-speed" when plugged into either one of the two USB 3.0 ports. Sometimes I have to reboot my computer for my memory stick to operate at USB 3 speeds. As I said, I can never get my external HD to operate at SuperSpeed. This leads me to believe that it's not the fault of my external HD but something else.
I have installed Etron EJ168 USB 3.0 Host Controller drivers 0.115 and now 0.118 hoping it solves my problem. I have also disabled legacy USB 3.0 support in the UEFI (BIOS) and set legacy USB support to UEFI only. Power saving features of the USB ports are off too. Nothing is working, any ideas? I have attached two pictures to this thread for you to look at:
Windows 7 x64 Home PremiumIntel Core 2 Quad 9450 @ 3.2GHz2x2GB Corsair XMS2 DDR2 (PC2-6400) 4-4-4-12XFX Radeon HD 4890 XXX 1GB
Abit IP35 Pro XE
Creative Sound Blaster X-fi XtremeMusic
Hyundai W240D-PVA 24" LCD Monitor
Hitachi Deskstar 7K1000 750GB
Corsair HX Series 620W
Antec Plus 1080AMG Metallic Gray Case
Possibly 2 x 4 ports, 4 for each of the 2 rear physical ports.
Do you get the "This device can perform faster" warning pop up when speeds are stuck at USB 2.0?
Windows 7 Ultimate x64 SP1AMD Phenom 2 1090T2x8GB Kingston HyperX Fury Black 1600Mhz Unga...MSI GTX 970 Gaming 4G
AMD Phenom 2 1090T
Gigabyte GA-890FXA-UD5
3xAcer GD245HQ
HighPower 1000W
Cooler Master HAF 932
Noctua NH-D14
Logitech G19
Logitech G500
IE 11 - Firefox - Chrome
I wouldn't recommend disabling Legacy. It allows you to use either USB 3.0 or USB 2.0 devices.
    ALWAYS UNDER CONSTRUCTION
    Windows 11 Pro
    Ryzen 9 5900X
    Asus X570 Crosshair Viii Hero
    32GB G Skill DDR4-3600
    EVGA RTX 3080 FTW 3 Ultra
    3 X Asus 27"
    2 X 1 TB NVME drives
    EVGA 850
    Phanteks Eclipse P400A
    EVGA 280 AIO
    Logitech G510s/ Logitech G13
    Logitech G502
    ESET/MBAM Pro/SAS Pro
    Chrome/ Firefox/ Edge
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
I'm pretty sure Legacy USB enables support at boot for use in BIOS, the best mode I've found for that is AUTO. If legacy devices are connected they will be enabled, if not the feature is bypassed. I played around with that a lot trying to get rid of my strange unremovable device showing in Disk Managament, and if I remember correctly disabling it didn't affect me. I could be wrong there though, I'll have to try and dig out the old thread.
It would also help if the OP stated what speeds his devices are actually transferring at, USB 3.0 guarantees nothing other than it is faster than USB 2.0. Speeds will vary depending upon each device.
W7 Pro x64 SP1 | W10 Pro IP x64 | W8.1 Pro x6...i7-4790k @ 4GHz (4.4GHz Boost)16GB DDR3 Kingston HyperX Fury @ 1600MHz CL 9...EVGA GTX 980 Classified
Realtek Onboard
Samsung S27D390
240GB Intel 520 Series SSD |
Samsung 850 EVO 120GB SSD |
2TB WD Caviar Black |
2TB WD Caviar Green
Corsair HX850-80 Gold Modular
Cooler Master Silencio 650
Microsoft Sidewinder X4
Gigabyte M6900 optical
152mb
F-Secure
Firefox 38.0
No, I don't ever get that pop-up message but the USB Device Tree Viewer tells me whether the device is connected at high-speed or SuperSpeed.
I've messed around with legacy USB options, nothing is helping to be honest. The speeds I am getting is irrelevant in my opinion because USB Device Tree Viewer tells me when the USB 3.0 port is connecting to the attached device at High-Speed or SuperSpeed. We know High-Speed is USB 2 and SuperSpeed is USB 3. It's worth mentioning that my WD external HD is a USB 3.0 device and has a USB 3.0 cable (indicated by the blue plastic inside the USB ends and an SS label)
Abit IP35 Pro XE
The speed you're getting is relevant though, I have four USB 3.0 Kingston Data Travellers that only transfer at 10Mb/s (at best) even they show up as super speed whereas my Hitachi Touro Mobile USB 3.0 external HDD transfers at over 100Mb/s consistently. USB 2.0 drives at work transfer faster than my Data Travellers.
Realtek Onboard
Samsung S27D390
2TB WD Caviar Green
152mb
F-Secure
Firefox 38.0
My 1TB WD Passport (USB 3.0) tops at 60MB/s.
AMD Phenom 2 1090T
3xAcer GD245HQ
HighPower 1000W
Noctua NH-D14
Logitech G19
Logitech G500
That's my point, some devices will transfer at super speed whereas others are bordering on being sold under false pretenses.
Realtek Onboard
Samsung S27D390
2TB WD Caviar Green
152mb
F-Secure
Firefox 38.0
TBH I think its something you may have to live with, unfortunately your equipment predates USB 3 chipset support (I have similar problems to you) so manufacturers added 3rd party chips to their motherboards as a stop gap.
Im not sure of the exact point when USB3 was truly integrated but it was around Ivybridge chips but most if not all Z68/H61 etc chipsets suffer with these problems.
It improves slightly with B75/Z77 era equipment but I don't believe it was truly sorted until Haswell chipsets, coupled with the fact that win7 doesn't have native USB3 support it can be an issue, although Win 8 does have native support I have never really used it so not sure if that works better with the older chipsets ??
I have tried numerous setups/variations/driver reinstalls etc on H61/B75/H77/Z77 motherboards and have never truly got them to work 100% correctly 100% of the time
I have a few Toshiba USB 3 backup drives that have an activity LED that lights white for USB2 and blue for USB3 and it still seems pot luck at which speed it connects at, my home machine goes blue 90% of the time and my transfer speeds are reasonably good so I have left it alone for a while now but it still occasionally goes white and nearly always connects at USB2 at the office (H77). I have just accepted this now and will live with it until I go to newer hardware
Win7 Ultimate X64Intel i5 3570K8GB DDR3 1600Onboard
Pauly Special
Win7 Ultimate X64
Intel i5 3570K
Gigabyte Z77X-DS3H
8GB DDR3 1600
Onboard
Onboard
1280x1024
Samsung 840 Evo SSD (OS)
1TB Spinner (Data)
800W Arctic
Cooler Master
3x120mm Fans
MS Wireless
MS Wireless
20M
As Pauly alluded to, no matter what connection you use, it will always be limited by the write speed of what you are transferring to. No matter how fast your connection is able to transfer data, you can't transfer it faster than the device you are connect can write. There are other factors involved too, but that is the primary one.
    Windows 11 Pro
    Ryzen 9 5900X
    3 X Asus 27"
    EVGA 850
    EVGA 280 AIO
    Logitech G502
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
It seems that my motherboard is out of date when it comes to USB 3. I will eventually upgrade and hopefully USB 3 will be more readily available.
I am transferring files from my Sata 3 HD and my SSD. My external HD is listed as USB 3 and reviews I have read suggest it works fine as a USB 3 device. I'm getting between 2 - 25mb/sec. My equipment can write faster than that surely.
Abit IP35 Pro XE
