Solved Using USB 2 Device With USB 1 Cable
jsquareg
Power User
4:39 AM
I plan to replace my MB soon and the new MB will have at least USB 2 native capability. The front panel USB ports on my case are now, of course, USB 1. If I connect them to the new MB's USB headers will that offer any problems to USB 2 devices?
Thank you.
Dell XPS-8500
Windows 7 Home Premium (Retail) Full version - With SP1
3.10 Gig Intel Core i5-3350P
Dell 0NW73C A00
8192 Megabytes Usable Installed Memory
Samsung SyncMaster [Monitor] (19.1"vis, s/n HVELA10194, Octo
1024 X 768
INTEL SSDSA2CW120G3 ATA Device [Hard drive] (120.03 GB)
INTEL SSDSA2CW080G3 ATA Device [Hard drive] (80.02 GB)
HID Keyboard Device (HP)
Dell (came with computer)
cox high speed
The above taken with Bel Arc Advisor
No...USB2 is backwards compatible so you should have no issues...
However USB2 devices will run at the lower speeds when connected to your front USB1 ports.
2 things to look into is see if any newer USB front headers will fit your case...that or add a PCI USB3 expansion card for more ports.
Self-Built
Vista Ultimate X64/ Windows 7 Dual-boot
Q6600
ASUS P5K
4G OCZ PC2 8500 Platinum
EVGA 8800GTS Vid Card
500G Seagate SATA
200G Seagate SATA
100G WD Caviar SATA
80G WD Caviar IDE
OCZ Elite 800W PSU
RaidMax Smilodon Case
Thank you very much.
That is exactly what I wanted to know. I was afraid your second comment, the one about speed, would be the case so I guess I will find a new USB front header.
Thanks again.
Dell XPS-8500
Dell 0NW73C A00
1024 X 768
cox high speed
I don't wish to be insulting, but I don't believe this.
As far as I know, motherboard headers are the same for USB1 and USB2, and so are the cables. Same number of conductors, in the same physical configuration. No additional keys or slots.
I believe that you'll get USB2 data rates from your front panel. This assumes that your front panel connection isn't discrete wires like I've seen in old PC cases.
USB3 is another story. The older USB connector isn't compatible with it. Some motherboard makers supply an adapter to allow older USB front panel connectors to use the USB3 header on the motherboard. (At USB2 data rates. Apparently the board detects the missing wires.)
Corrections will be cheerfully accepted.
homegrown
Windows 7 Pro X64 SP1
Intel Core I7-3930k
Asus P9X79 Pro
16 GB Gskill DDR3-2133
eVGA GTX680
Creative X-Fi Titanium
As PA246Q
1920 X 1200
Corsair Force GT, 120 GB
WDC 1.5TB Caviar Black
PCP&C Silencer 750 Crossfire
Silverstone FT02
Noctua NH-D14
cheap Logitech USB
Microsoft Intellimouse Explorer (old optical) USB
6Mb cable
Pioneer BDR-205
Samsung SH-203B
Monsoon 5.1 speakers
