VB Audio Virtual Audio Cable Input and Out put mixed up
ScholarlyTurtle
6:54 AM
Hello.
At the moment my only "pair" of headphones has only one working speaker (the other is missing!), so I've been using VB Audio Virtual Audio Cable to combine both channels and play them through the left earpiece. Recently, though, I fell for one of those stupid driver updater scams, which installed that annoying RealTek bloatware, and I'm not sure if it was then or some time afterwards that this happened.
My output is where my input should be and vice versa. I can't find anything relevant elsewhere, so I decided to post here. Any suggestions? Thanks in advance.
HP Compaq 505b MT
Windows 7 Professional
AMD Athlon II X2 245
PEGATRON CORPORATION 2A99h
DIMM DDR3 Single-Channel 2GB Memory Device
AMD Radeon HD 5450
ST350041 8AS SCSI Disk Device
Avast Free Antivirus
Pale Moon
You'd best start out and create a new Virtual Audio Cable. Rather than edit/delete the VAC you already have.
Here, I used this video 2 months ago. https://www.bing.com/videos/search The explanation is crystal clear. He is using skype and teamtalk, but you can adjust for your own microphone.
Windows 7 x64, Vista x64, 8.1 smartphone
Intel E8400 65W 64-bit
Gigabyte EP45-UD3LR
DDR2 2 x 2GB, 1GB x 2
XFX Radeon HD5750
AMD High Definition Audio; Realtek High Definition Audio
iiyama prolite X2377HDS
500GB 7200 rpm Seagate ST3500413AS 16MB, 500GB 5400 rpm Toshiba MQ02ABF050H 32MB, 200GB 7200 rpm Seagate ST3200820AS 8MB, 2TB 7200 rpm Western Digital WD20EZRX 64MB
Enermax Liberty Modular
Antec P193 Midi Tower
Mionix ZIBAL 60
Razer USB 2.0 Diamondback Mouse or Huion Graphics Tablet
Internet Explorer, Lunascape, Firefox, Opera, Avast Safezone
Sorry, but that's irrelevant. :(
Sorry for the super-late reply, but I'm using the VB Audio Virtual Audio Cable at
VB-Audio Virtual Apps
not the one in the video, so that doesn't help. Happy Thanksgiving, though.
HP Compaq 505b MT
AMD Radeon HD 5450
Pale Moon
