Solved What are you're Cpu and System Temps ?
i feel like my cpu runs hot... maybe not. ambient temperature is 75.8­°F -> 24.3°C
edit: the highs were during gaming
I would say these would be about right for intel those chips are really heat prone i used intel for like a good 19 years now that i switched to amd ati products im finding my machine has less cooling issues compared to my always intel nvidia mix
I always liked nvidia but now days the product is too high and with alternitives it is easy to sway to diffrent products i am happy with my choice just hope the good work by amd keeps going
Enthod Pro Full Tower
Logitech wireless keyboard
Logitech wireless mouse
Cox Cable 100+ mb
IE-10, Chrome, Opera
GPU GTX Gigabyte 970G1
i dont know why it gets so hot when gaming, that shouldn't max out the processor... if it ever did max out i feel like it would melt...
Windows 7 64-bit HomeIntel Core i7-870 Lynnfield 2.93 Ghz8GB 4x2 A-Data 1333 MhzHIS Radeon HD 5850 1GB
My First Build
Asus P7P55D-E Pro
Onboard
Dell S2440L 24"
1080p
120 GB Intel X25-M SATA Solid State Drive ///
1 TB Western Digital Caviar Black SATA 6gb/s 7200rpm Drive
Corsair 650TX 650 Watt
Antec Three Hundred
Stock Intel /// 4 Antec Case Fans /// NZXT Sentry-2
Logitech LX 710
Logitech LX 710
LG Blu-Ray Drive
it always could be worse you could always have shut downs and have to remove the case panels and stick a fan to it the last intel i had ran so hot you couldnt keep the case closed
I am using the same case now with the amd stuff and it runs alot cooler then the intel way cooler
Cox Cable 100+ mb
After a good cleaning my temps are very low :D
W7 Professional x64AMD Athlon II X3 445 Rana 3.10 GHzPNY XLR DDR3 1600 4x2GBNVIDIA GeForce GTS 450 (fermi) 1GB GDDR5
Pugh Technologies
W7 Professional x64
MSI 870A-G54
Realtek ALC892 onboard
ASUS VE205t, Viewsonic VX2035WM
1600x900, 1600x1050
977GB Hitachi Hitachi HDS721010CLA332
244GB Western Digital WDC WD2500AAJS-65B4A0
488GB Western Digital WDC WD5000AAJS-00A8B0
488GB Western Digital WDC WD5000AAKS-00UU3A0
Antec EarthWatts EA650 650W
ThermalTake Armor A90 Mid Tower
3x 120mm in, 1x 120mm & 200mm out, self built hydro-cooler
Logitec 55
Razer Deathadder
20 Mbps D/L, 9 Mbps U/L
Here's mine for reference only.
Windows 7 Pro X64Intel core I7 950 3.06GHZ CPU12Gb Corsair TR3X3G1600C8D 1600MHz 8-8-8-24-2T2 X MSI Cyclone GTX460 1Gb Oc 840/3800
Windows 7 Pro X64
ASUS P6X58D Premium LGA1366 X58
Realtek HD
2 x HP 2159m monitors 1920 x 1080
Intel X25-M 160Gb SSD
2 x Seagate Baracuda 750Gb @ 7200rpm
Corsair HX1000W
Cooler Master Storm Sniper Black Mesh
Corsair H70 Water cooling
ADSL 2+
