WiFi connection Problems with "free" Wifis - More Info about Problem?
I have connection Problems to Wifis ...
I want to connect for example to eduroam (free for students in Europe) ... I enter my Credentials -> but all I get is:
Windows was unable to connect to "eduroam"
[Troubleshot problems]
[Tell me more about Internet connection problems]
I get the same for "UPC Wi-Free" (=Free WiFi of my Provider): here I have to setup the connection manually, described by the provider - but the result is the same ...
So as the screenshot is not providing so much information ...
where in Windows do I get more information what was not matching?
Credentials? Some Protocols? Certificates ...
Where do I find such infos for WiFi ?
Where do I find this Link?
Do you mean "[Tell me more about Internet connection problems]"?
This only provides some generic info about general connections problem ... like checking connection cables, restart Modem, ... useless.
No, It does not ...
simply tries to fix the probelm ... only thing I can "see" is that it is deactivating the wireless adapter and activates it again ...
Than it says something like I can try to restart the modem/access point (I can not!) and check the cables (it is wireless)
giving two option -> check if fixed (is not) -> try fixing again (fails: and no more Info)
