- Local time
- 2:10 PM
- Messages
- 50,634
Will 3pin CPU fan plug work with 4 pins on mobo?
I've pulled the old Fan out. When I google the PN: hi. 10800.028 e
I learn it's Socket 775, 95mm which I confirmed by measuring fan diameter.
Tiger Direct shows this right-priced replacement model which matches every spec except it has a 3 pin plug: VALUE SOCKET T/775 HEATSINK at TigerDirect.com. They don't know if 3 pin plug works when 4 pins are present on mobo and original part has 4 pin plug.
There's also this used one which exactly matches PN: Acer HI.10800.028 Heatsink and Fan Gateway AX3400G X1420G X1920G
And this one for twice the price that matches even the Acer model number: New Acer Aspire X1200 X1300 X1301 X1800 X3200 X3300 X3810 Cpu Fan. But he doesn't wanna spend that much.
We only need the fan.
