Solved Wireless Adapter Problem? Can't hold connection
ravalos
12:23 PM
Vancouver, Canada
A couple days ago while my laptop would say I was connected to my network and had Internet access I couldn't even ping Google, even though I had been using Internet for the past hour or so. My roommate and my phone have no problem connecting to the Internet, it only seems to be my laptop. It's been on and off but it's getting worse now, I can only access the Internet through a wired connection while my roommate, his phone, and my phone have no difficulties. It says I'm connected with Internet access, but I can't access anything apart from something that's intra-network.
Any suggestions? I feel like it's my wireless adapter (built in) giving me problems, I've tried a system restore to before the problem started, it didn't work. I also uninstalled the adapter from device manager and restarted my laptop so it could install again. It did install again, but there hasn't been a change. I've also tried changing my IP address on the router.
My laptop is an Acer 5741G, the network adapter is a Broadcom 802.11n Network Adapter. The router is a linksys WRT54G v2.0.
Thanks for any suggestions.
7 Ultimate 32-Bit
Intel Q6600
Gigabyte GA-P35-DS3R Rev. 2.1
NVIDIA 8800GT
Hello ravalos,
You might want to verify if you have the latest driver for your Broadcom WiFi adapter to be found from the Manufacturer's site.
If that didn't help please post an ipconfig /all output for review.
Also, please list all your AV/Firewall/Security Software installed.
Lenovo Desktop/Samsung Laptop
Win7 & Win8 64bit
Intel i5
Charter-20 Mbps
FF, IE9 and Chrome
Hello ravalos,
Hi 2xg,
Sorry for the delayed reply, since it's been off and on I couldn't really tell if the latest driver had worked till now when I'm at the same problem. Right now it disconnected me from my network and when I try to reconnect it says Windows was unable to. I've restarted as well right now and I can't connect to any wireless network at the moment.
The only Firewall I have is the one that comes with Windows 7, my AV is Kaspersky Anti-Virus 2011.
My ipconfig /all output is as follows:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Ravalos>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Ravalos
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Mixed
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter
Physical Address. . . . . . . . . : F0-7B-CB-22-74-43
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Broadcom 802.11n Network Adapter
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Broadcom NetLink (TM) Gigabit Ethernet
Physical Address. . . . . . . . . : 70-5A-B6-CF-BC-78
Link-local IPv6 Address . . . . . : fe80::4566:c8e4:df57:a82e%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.108(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : September-29-11 1:33:38 PM
Lease Expires . . . . . . . . . . : September-30-11 1:50:41 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 242244278
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-3D-F0-79-70-5A-B6-CF-BC-78
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.vf.shawcable.net:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Reusable ISATAP Interface {B3CA6DB3-389F-44C0-8383-21CA40E7F904}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:20b1:d26:e709:f15c(Prefe
rred)
Link-local IPv6 Address . . . . . : fe80::20b1:d26:e709:f15c%22(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{EB112CCF-0FE6-4CBF-A8E5-30033E1DEC24}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #11
Tunnel adapter Reusable ISATAP Interface {27591E5D-D585-457C-9E26-37A64686C823}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter Reusable ISATAP Interface {B5A27842-BAC4-4B0A-919D-8F0E64A8E910}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #9
Tunnel adapter isatap.{1C48EF26-6DA9-4916-81BB-75609E972A9E}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #8
Tunnel adapter isatap.{C4A45463-C1F9-41EB-A3A1-B02CCD2AF28F}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #12
Tunnel adapter isatap.{037C3988-F9DE-474C-9699-6ADB32526283}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
7 Ultimate 32-Bit
Intel Q6600
NVIDIA 8800GT
Win7 & Win8 64bit
Intel i5
Charter-20 Mbps
FF, IE9 and Chrome
