wireless connection problem
lty
4:56 AM
i can search the router but just can't connect to it and the problemshooter can't tell me the reason why it's like that
i am using realtek rtl8187 wireles 802.11g 54Mbps USB 2.0 network adapter
windows 7
Hello lty, welcome.
Can you describe your problem some more? You say you can search it? What does that mean? But you cannot connect?
~Lordbob
Hera
Intel i5-2500k
ASUS P8P67 Pro
Realtek HD OnBoard Audio
ASUS 24" Monitor
Cooler Master Haf 932
Fans
Razer Tarantula
Razer Lachesis
not fast enough
when i check the available connections, i can find the router with full signal, but after typing the password and click the connect button, it said unable to connect
windows 7
I have had this issue before, you will need to hard-reset the router. What make/model is your router in case you need assistance resetting it?
Compaq Desktop
AMD Sempron Dual Core
3GB
1024x768
150GB Sata
sounds like an association problem between your router and wireless adapter, as said before hard resetting your router could help.
dont ever rely on microsoft troubleshooting,probably the biggest thing i hate about all windows stuff the troubleshooting of everything sucks and doesnt help much at all.
Dual Boot : Windows 7 7264 X64/Windows Vista Ultimate
AMD Athlon 64 X2 Dual Core 5000+
Gigabyte MA78GM-S2H
4x 1GB OCZ Platinum 800MHZ
Radeon HD3200 On Board
On Board
Dell 2208WFP
Western Digital Caviar blue 320GB
Corsair HX620W
CM Storm Scout
Foxconn Stock Heatsink
Keysonic Wireless
8MB
sorry, what's the meaning of hard-reset the router?
what should i do?
i am using buffalo whr-g54s
windows 7
Hard reset
what should i do?
There are a couple of ways on most routers there is a button that resets to factory defaults. If you dont have that unplug and leave unplugged for abt a minute
Tip when hard reseting the admin and password revert back to what it was from the factory (admin, password)
Good luck
Ken
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
what should i do?
Ok, i'm assuming that this This is your router :p
This whoud be what you're after
For Vista/Seven the settings (once reset) will be automatically detected.
Hope this is helps :)
Jeff
Compaq Desktop
3GB
1024x768
150GB Sata
thanks, the problem is solved:)
windows 7
Glad you got it fixed lty.
Sometimes things just need a nice reset :D
~Lordbob
Hera
Intel i5-2500k
ASUS P8P67 Pro
ASUS 24" Monitor
Fans
Razer Tarantula
Razer Lachesis
not fast enough
