Wireless connection problem
fireman0174
5:53 AM
I have a MacBook that I just partitioned with Windows 7. I'm unable to connect to my wireless home network with W-7. The connection on the MAC OS works fine using wireless.
Also, I am able to get an internet connection with W-7 using an ethernet cable from the router.
Any assistance, or point me in the right direction would be appreciated. :)
XP
Did you install the wireless drivers?
Dell XPS 15 L502x
Core i7-2670QM
8GB DDR3 PC3-10600
Intel HD Graphics 3000 + GeForce GT 540M
1TB 5400RPM Seagate
From the Macbook install DVD? I installed a bunch of utilities, but I'll go back and double check.
Or do you mean from the W-7 installation disk?
XP
I had some 79 Windows updates to go through after the initial installation. After they were done, the issue was solved - I assume one of the updates did the trick.
Anyway, thanks for the assistance.! :D
XP
Windows 7 trouble shoot should have done the trick lol
Windows 7 Ultimate
AMD A6 3650 2.6 GHz
ASRock A55M-HVS
8 Gigs
Radeon HD 6870
42" Dynex Screen
1360x768
60 GB OCZ SSD - Sata III 2.5"
150 GB HDD
250 GB HDD
Raidmax RX-500AF
Rosewill Blackbone Black Steel
4 Fans
6 mbs
Freshly put together, my first build, my own hard earned cash, an im 17.
