Wireless G PCI Adapter
matt2403
8:20 PM
Hi, i have recently gone from vista home premium to windows 7 and now my wireless adaptor does not work. i have reinstalled the software a few times and still no change. Also the green light at the back is not turned on and it is not found in the device manager. It is a Linksys Wireless-G PCI Adaptor , 2.4ghz 802.11b/g Dish Antenna.
Thanks,
Matt
I've been using a Linksys WUSB600N sucessfully with Windows 7 so all I can imagine is that:
1.You don't have the correct drivers.
2. Your USB port is not configured
If you unplug it and re-plug does your Windows recognize that it's plugged?
MSI
Windows 7 Professional 64bit
Intel Celeron 2.4 GH
NVidia GeForce 9800GT
ATI HDMI Audio
Acer S231HL Dual Monitors
Hitachi 300GB ATA
Maxtor 300GB USB
Standard
Logitech wireless
Logitech wireless
Cable
thanks for the reply
it does not show up on windows at all.
and i downloaded the files and transferred it onto my computer but nothing seemed to change ?
thanks
matt
You have to use winrar to extract the files from the .zip to a folder on your pc. You can extract to the desktop to make it easy. Then you need to update the driver using device manager, right click on network adapter, update driver software, browse my computer for driver software, let me pick from a list, have disk, browse.
Now find the folder you extracted and choose the .inf in it.
self built
7600.20510 x86
P4 550 3.4 GHz HT running at 3.5 GHz
MSI PM8M3-V (MS-7211 v1.x) Micro-ATX mainboard
OCZ 2 GB(2x1GB) DDR400mHz running @ 414 mHz
HIS Radeon HD 3850 IceQ 3 Turbo HDMI Dual DL-DVI AGP
MOTU Traveler firewire studio interface 192 kHz 24 bit
22" widescreen Acer X223W LCD, 17" Compaq P75 CRT
1680x1050 and 1280x1024
SATA I x2 WD, 400 GB and 120 GB, SATA 2 WD Caviar Black 1 TB
350W generic
Cybertronpc, it glows blue
stock cpu fan, Ice-Q 3 gpu and system, many case fans
Logitch Classical Keyboard 200
Logitech Mediaplay cordless
1792/448 kbits/sec
SATA II PCI fake RAID adapter, 1 GB Readyboost, original ATI Remote Wonder (even works with WMC perfectly), Logitech Rumblepad 2 game controller x2
ok so i used another memory stick and it works, except for the fact when i go on device manager the adaptor does not show up?
