Wireless Network Connection Problem (only with 7!)
thewayfarer
6:54 PM
I recently upgraded to Windows 7 and I went out earlier and bought a Linksys Wireless N (WRT120N) router. Hooked it all up, no problem - installed routers a billion times before. Once the wireless network was setup, I plugged my laptop in using a cable and the internet worked fine (still does). Next, I used my friend's laptop (which has Vista on it) and connected to the wireless network just fine. Now, unplugged my own laptop (the one using Windows 7) and tried to connect to the wireless network I had just set up, and it is unable to connect.
I'm still a Windows 7 noob, but I've pretty much tried everything I know to get it to connect. The network shows up when I search for wireless networks, but when I attempt to connect to it I get "Windows was unable to connect to (network name)". If I try the troubleshoot option, it only tells me to "investigate router or access point issues" and trying to resolve the problem gets me "Windows cannot resolve your wireless connectivity issue".
Any advice would be fantastic, as I'd like to get some use out of this thing.
PS - Some more info:
I have a Intel® Wireless WiFi Link 4965AGN.
I've tried deleting and re-adding the connection.
I've tried unchecking IPv6.
Hi and welcome.
As a temporary test, maybe take security off router and see if you can connect.
self built
7600.20510 x86
P4 550 3.4 GHz HT running at 3.5 GHz
MSI PM8M3-V (MS-7211 v1.x) Micro-ATX mainboard
OCZ 2 GB(2x1GB) DDR400mHz running @ 414 mHz
HIS Radeon HD 3850 IceQ 3 Turbo HDMI Dual DL-DVI AGP
MOTU Traveler firewire studio interface 192 kHz 24 bit
22" widescreen Acer X223W LCD, 17" Compaq P75 CRT
1680x1050 and 1280x1024
SATA I x2 WD, 400 GB and 120 GB, SATA 2 WD Caviar Black 1 TB
350W generic
Cybertronpc, it glows blue
stock cpu fan, Ice-Q 3 gpu and system, many case fans
Logitch Classical Keyboard 200
Logitech Mediaplay cordless
1792/448 kbits/sec
SATA II PCI fake RAID adapter, 1 GB Readyboost, original ATI Remote Wonder (even works with WMC perfectly), Logitech Rumblepad 2 game controller x2
Sorry, what do you mean by that? How would I go about doing so?
He means take the password off and see if it makes any difference.
And what i would like to ask, did this W7 come with your laptop, or did you go out and buy it?
W7 RTM Ultimate x64
Intel Q8400 @ 2.66GHZ
Gigabyte GA-EG45M-UD2H
4GB DDR2-800
Integrated 8 Channel
AOC 23.6 Inch Widescreen LCD
Seagate 500GB Internal
Western Digital 1TB Internal
Hitachi 1TB External
Apevia Java Power 500W
Cooler Master HAF 922 Black
Stock Intel CPU Fan
1.5MB
