redtuiop
I know this "problem" probably has a very simple solution, but forgive me, I'm currently brain dead (thanks to chronic pain meds) & can't figure out how to go about it.
I'm using Win 7 with a rather old HP Scanjet (which I know isn't supported etc, but it works perfectly for my needs & is the only one I've found that can adequately scan thick documents, in my case, decoupage cards), and a Canon IP4700 printer with manually refilled inks.
Now, my problem currently is that I suspect the scanner to perhaps be part of the problem, but when I scan particular papers (background papers that I use for putting on the cards), the colours never seem 100% what I want. And certainly, when it comes to printing, they are far removed from the original e.g. pinks turn out lilac, blues turn out grey, & reds turn out pink (of sorts).
Since I can't afford to start buying full price inks again, and can't find another scanner that will do the job I need, I'm lost as to find a way of at least figuring out perhaps which hardware is the culprit.
Or, is it likely that in the current setup I'm never going to succeed in being able to get reasonable accurate colour copies of anything I scan?
Finally, does anyone know of any other quality scanner that could cope with thick items (all the previous ones I tried, in particular, AIO's, couldn't in any sense), so that perhaps I could maybe find a cheap secondhand one to try??
Thanks for any input/suggestions you could provide for me.
- Computer type
- PC/Desktop
- Generic
- Win 7 64bit SP2?
- Intel G2030 3GHz
- Motherboard
- Gigabyte Motherboard GA-H61M
- 4 Gb
- Graphics Card(s)
- OnBoard
- Sound Card
- OnBoard
- Monitor(s) Displays
- BenQ GL2250
- Screen Resolution
- 1920 x 1080
- Hard Drives
- 3 x SATA (500, 1000, 2000)
- PSU
- 460W Coolermaster
- Case
- Coolermaster
- Cooling
- 3 x Fans
- Keyboard
- Microsoft Ergonomic 4000
- Mouse
- Kensington Trackball
- Internet Speed
- 100 Gb
