XFX Radeon HD 6770 not Working because of my power supply?
goisek
8:41 PM
Studio XPS 435MT
If you had the 6 pin adapter your psu couln't handle the card, I think it requires at least 500 watts and yours is 360 watts :( These beasts require a lot of power and you second image shows us you pc not your cpu (cpu is under the large fan)
I have two ideas.
1.) Sell the card and stick with the default card.
2.) Buy a psu running at least 600w with the 6 aux pin adapter.
I suggest the first option as these pcs are meant to work with the default hardware. If you really require a graphics card try a low profile card as there more economical and a better size.
Windows 7 Professional (x64/SP1) /Linux Mint 16Intel i5-3570k 3.40 GHz @ 4.6 GHz8GB (2133MHz) DDR3Asus GTX560 Ti (Nvidia)
GIGABYTE Rig (Custom)
GIGABYTE Z77X-D3H
8GB (2133MHz) DDR3
HP 23", Acer 19" and a Dell 17"
1080p, 1440x900 and 1280x1024
Sandisk Extreme 120GB (SSD), WD 2TB green and 4 other HDDs
Antec 620w High Current Gamer
Corsair Obsidian 600D
CPU - Antec KÜHLER H₂O 920
Steelseries 6Gv2
Roccat LUA
4 - 6mb/s
ESET NOD32
Chrome/Firefox
Intel Gigabit CT (PCIE NIC) and Thinkpad T61p,
Studio XPS 435MT
Welcome to Seven Forums.
Well first off your PSU is under powered for that card.
You also should have received a dual molex to 6 pin adapter with your card, if not you can purchase them.
Minimum system requirements AMD Radeon
Fabe
Windows 7 ultimate 64 bit / XP Home sp3intel Core 2 Duo E8400 3.0ghz8 gigs 1066 OCZ Fata1tyEVGA GTX 580 Call of Duty Black Ops Edition
Asus P5ND bios 1401
Asus 24in LCD's 2MS X2
1920x1080p @60Hz
OCZ 700W GameXtreme
NZXT Apollo
Download 19.83 Upload 0.97
Will this PSU work? Cooler Master - eXtreme Power Plus 500-Watt ATX CPU Power Supply, i have no experience on hardware stuff will this be a big problem when installing the PSU or i can do it?
That psu should be fine but I would get someone with computer knowledge to install it as if its done wrong you can fry your components. Its not hard its just knowing what to do.
GIGABYTE Z77X-D3H
8GB (2133MHz) DDR3
Steelseries 6Gv2
Roccat LUA
4 - 6mb/s
ESET NOD32
Chrome/Firefox
Studio XPS 435MT
I would go with the Corsair if I was choosing between the 2.
Your power supply is one of the most important components in your system so you don't ever want to skimp on it.
This would also allow for future upgrades. And since it states it's a gaming seiries it should have the 6 pin connectors you'l need. Make sure before buying.
Installing a power supply is easy enough as long as you take your time and make note of where the existing connections are.Plenty of video's to help you out how to install a power supply - Yahoo! Search Results
Fabe
Asus P5ND bios 1401
1920x1080p @60Hz
OCZ 700W GameXtreme
NZXT Apollo
thank you so much im going to buy this Corsair - Gaming Series 600-Watt ATX CPU Power Supply now, i'll just have to remember where is the wire connected before installing right? then put the new one?
Studio XPS 435MT
It's not that difficult. Just make a diagram if you need to. The connections can only go where they are supposed to and only go on one way DON'T force anything. The ends are shaped to only fit in one way. So take your time, watch a couple of video's, maybe even take a picture if your worried.
Or you can always have it done by a shop for only maybe half an arm.
Fabe
Asus P5ND bios 1401
1920x1080p @60Hz
OCZ 700W GameXtreme
NZXT Apollo
