Zoom problems with certain Programs and Right click>drop down menus
Mariexx
Banned
8:52 AM
Alright. So this just happened, and I have no idea how it happened, and how to fix it. So some help would be awesome.
California
California
Marie,
OS is an abbreviation for Operating System.
Please use following to fill out your System Specs.
Update your SevenForums System Specs
User CP (located on the top menu bar) |
Your Profile | Edit System Spec
(left-hand column)
To gather info, use Speccy (my favorite) orSIW or System Info
Add the word laptop or desktop or netbook to the
“system manufacturer” block, for example,
Toshiba Satellite L305D notebook.
Provide full windows version info, for example:
Use the “Other Info” block for Optical Reader,
Mouse, touchpad, wifi adapter, speakers, monitor, etc
Scroll down and click on SAVE CHANGES.
What anti-virus software are you using?
MS Windows 7 Ultimate SP1 64-bitAMD A10-4600M6.00 GB Dual-Channel DDR3 @ 798MHz (11-11-12-28)AMD Radeon HD 7660G
AMD A10-4600M
AMD Pumori (Socket FT1)
AMD Radeon HD 7660G
High Definition Audio Device
1600x900@60Hz
Standard PS/2 Keyboard
This is all I can show you, since I'm not really computer Savvy. I'm not sure what I'm supposed to be doing.
California
California
Marie,
Just follow the write-up as thousands before you have done.
Thanks for your cooperation.
AMD A10-4600M
AMD Radeon HD 7660G
1600x900@60Hz
Still no change
California
California
