RAM - Test with Memtest86+
Page 1 of 14 12311 ... LastLast
    How to Test and Diagnose RAM Issues with Memtest86+
    Contents
    Part 1: Preparing the Media
    Method 1: With a USB Memory Stick
    1. Download the latest version of the "Auto-installer for USB Key (Win 9x/2k/xp/7)" from this link: Memtest86+ - Advanced Memory Diagnostic Tool
    2. Plug in an empty USB key drive. Size is no concern, as the actual files take up 180 KB of space.
    3. Go into the .zip folder you downloaded, and double-click on the .exe file inside.
    4. Follow the setup utility. To reduce the risk of problems, it is advised to format the drive.
    Method 2: With a CD
    1. Download the latest version of the "Precompiled Boot ISO (.zip) from this link: Memtest86+ - Advanced Memory Diagnostic Tool
    You want the "Precompiled Boot ISO (.zip)".
    2. Open the .zip file you downloaded, and then drag the .ISO file inside onto the Desktop.
    3. Right-click on the ISO, and select Open with>Windows Disc Image Burner.
    4. Insert a blank CD into the CD drive, and make sure the correct Disc burner is selected.
    5. Click on "Burn".
    Now the CD is ready to use.
    Part 2: Testing
    1. With the CD in the drive, or the USB key inserted, reboot your computer. If Memtest does not automatically boot, go into the BIOS and change the CD drive or USB drive to be the first to boot.
    2. Memtest will immediately start testing as soon as it boots. No attendance is needed.
    3. Let it run until at least 8 passes are completed, or errors are found (whichever comes first). The longer you run it, the better.
    Seven passes will take several hours, depending on your amount of RAM. It is advised to leave it running overnight.
    Part 3: If You Have Errors:
    The goal is to test all the RAM sticks and all the motherboard slots.
    Check your motherboard manual to ensure the RAM sticks are in the recommended motherboard slots. Some motherboards have very specific slots required for the number of RAM sticks installed.
    If you get errors, stop the test and continue with the next step.
    1. Remove all but one stick of RAM from your computer (this will be RAM stick #1), and run Memtest86 again, for 7 passes.
    Be sure to note the RAM stick, use a piece of tape with a number, and note the motherboard slot.
    If this stick passes the test then go to step #3.
    2. If RAM stick #1 has errors, repeat the test with RAM stick #2 in the same motherboard slot.
    If RAM stick #2 passes, this indicates that RAM stick #1 may be bad. If you want to be absolutely sure, re-test RAM stick #1 in another known good slot.
    If RAM stick #2 has errors, this indicates another possible bad RAM stick, a possible motherboard slot failure or inadequate settings.
    3. Test the next stick of RAM (stick #2) in the next motherboard slot.
    If this RAM stick has errors repeat step #2 using a known good stick if possible, or another stick.
    If this RAM stick has no errors and both sticks failed in slot#1, test RAM stick #1 in this slot.
    4. If you find a stick that passes the test, test it in all the other motherboard slots.
    If Part 2 testing shows errors, and all tests in Part 3 show errors, you will need to test the RAM sticks in another computer and/or test other RAM in your computer to identify the problem.
    In this way, you can identify whether it is a bad stick of RAM, a bad motherboard, or incompatibility between the sticks.
    Thanks to Dave76 for his assistance in this part.
    While the same concept is completely valid for other operating systems, a different image burner will be needed. A good free program is ImgBurn.
  1. Posts : 17,796
    An excellent tutorial for all those that want to test their RAM. In addition, the BSOD Squad can give this tutorial to an OP with a BSOD that may be related to memory. Bravo.
  2. Posts : 13,354
    Windows 7 Professional x64
    Thanks. :)
    Now we don't all have to use my Memtest canned speech.
  3. Posts : 4,517
    Excellent!
  4. Posts : 11,990
    Windows 7 Ultimate 32 bit
    Superb, Jon; very well done. Thank you much. Tried to rep; but I gotta spread some around first.
  5. Posts : 845
    Windows 7 - Vista
    Great job, Jonathan !!
  6. Posts : 17,322
    Win 10 Pro x64
    Nice work JK.
  7. Posts : 17,796
    derekimo said:
    Nice work JK.
    You have no idea, how good. For the BSOD Squad its a gift.
  8. Posts : 17,322
    Win 10 Pro x64
    richc46 said:
    derekimo said:
    Nice work JK.
    I've seen quite a few posts there, so I can see this being a gift!
  9. Posts : 7,683
    Windows 10 Pro
    About time
    We needed a tut like this one here. The one I used to link to was rather long and technical. Good job
    +1
