Window Animations - Allow or Prevent
    How to Allow or Prevent Window Animations in Vista, Windows 7, and Windows 8
    This tutorial will show you how to allow or prevent window animations such as restoring, minimizing, and maximizing windows for all or specific users in Vista, Windows 7, and Windows 8.
    You must be logged in as an administrator to be able to do this tutorial.
    EXAMPLE: Animations in Visual Effects Settings
    NOTE: This is an example of the animations that will be affected no matter how it is set in the Visual Effect settings.
    OPTION ONE
    To Allow or Prevent Windows Animations using a REG File
    1. Do step 2 or 3 below for what you would like to do.
    2. To Allow Window Animations
    A) Click/tap on the Download button below to download the file below, and go to step 4 below.
    Allow_Window_Animations.reg
    3. To Prevent Window Animations
    Prevent_Window_Animations.reg
    4. Save the .reg file to your desktop.
    5. Double click/tap on the downloaded .reg file to merge it.
    6. If prompted, click/tap on Run, Yes (UAC-Windows 7/8) or Continue (UAC-Vista), Yes, and OK to approve the merge.
    7. Log off and log on, or restart the computer to apply.
    8. When done, you can delete the downloaded .reg file if you would like.
    OPTION TWO
    To Allow or Prevent Windows Animations Group Policy
    2. In the left pane, click/tap on the arrow to expand User Configuration, Administrative Templates, Windows Components, then click/tap on Desktop Window Manager. (see screenshot below)
    3. In the right pane of Desktop Window Manager, double click/tap on Do not allow window animations to edit it, and do step 4 or 5 below for what you would like to do. (see screenshot above)
    4. To Allow Window Animations
    A) Select (dot) Not Configured or Disabled, and go to step 6 below. (see screenshot below step 6)
    5. To Prevent Window Animations
    A) Select (dot) Enabled, and go to step 6 below. (see screenshot below step 6)
    6. Click/tap on OK. (see screenshot below)
    7. Close the Local Group Policy Editor. (see screenshot below step 2)
    8. Log off and log on, or restart the computer to apply.
  1. Posts : 1,158
    Win7 HP (x64)/Win7 Ultimate (x64)
    Thank you Shawn :)
    Have great day and regards
  2. Posts : 4,772
    Good Tutorial Shawn !
  3. Posts : 8,375
    Ever see those lags waiting for all files to animate when going to browse a folder full of ... icons for example? Disabling the animation part will be an asset for many! That will speed up file browsing for sure!
    Another good one! Keep'em coming! Shawn
    Attached Thumbnails Attached Thumbnails Window Animations - Allow or Prevent-iconmares.jpg
      My Computers
  4. Posts : 72,055
    You're welcome guys. Thank you. :)
