Downloads Library - Create
Page 1 of 5 123 ... LastLast
    How to Create a "Downloads" Library with Correct Icon in Windows 7 and Windows 8
    This will show you how to create a Downloads library in Windows 7 and Windows 8 that has the original default Downloads library icon with the blue arrow pointing downwards on a glass plate.
    EXAMPLE: Original Downloads Library Icon
    Here's How:
    1. To Download the Downloads Library Icon
    A) Click/tap on the Download button below to download the Downloads_Library.zip file that contains the original Downloads library icon.
    B) Save the ZIP file to your desktop.
    C) Double click/tap on the ZIP file to open it, then extract (drag and frop) the Downloads_Library.ico file to the location that you want to keep it at.
    WARNING: The icon file will need to remain at this location while it is being used (step 3) for the Downloads library. If you move it, then the icon will no longer be displayed for the Downloads library.
    D) Right click or press and hold on the Downloads_Library.ico file, and click/tap on Properties, General tab, on the Unblock button, and on OK. (see screenshot below)
    NOTE: If you do not have a Unblock button under the General tab, then the shortcut is already unblocked and you can continue on to step 2.
    2. To Create the Downloads Library
    A) In Windows Explorer, navigate to your C:\Users\(user-name) folder, then create a new library with the Downloads folder. (see screenshot below)
    B) Open the new Downloads library, and include the C:\Users\Public\Public Downloads folder. (see screenshot below)
    NOTE: If you like, you could include any other folder location(s) that you would like to also be included inside the Downloads library as well.
    3. Do step 4 or 5 below depending on if you are in Windows 7 or Windows 8.
    4. To Change the Downloads Library Icon in Windows 7
    A) Change the Downloads library icon to use the Downloads_Library.ico icon file at the location you have saved it to in step 1. (see screenshots below)
    For example, I saved my icon from step 1 to C:\Users\(user-name)\My Documents, so I would add the line below (right screenshot below) while changing the icon at step 5 at that link.
    <iconReference>"C:\Users\User-Name\Documents\Downloads_Library.ico"</iconReference>
    You would substitute the path in red to the full path of where you saved the Downloads_Library.ico file instead in step 1.
    B) Go to step 6 below.
    5. To Change the Downloads Library Icon in Windows 8
    A) Using OPTION ONE in the tutorial below, change the new library's icon using the Downloads_Library.ico icon file at the location you have saved it to in step 1. (see screenshot below)
    6. You will now notice that the Downloads library icon has changed.
    NOTE: See example screenshot at the top of the tutorial.
  1. Posts : 18,404
    Thanks Shawn, it worked out.
  2. Posts : 72,061
    You're welcome Aaron. :)
  3. Posts : 114
    Windows 7 Build 7229 x86
    Thanks Brink Icon looks great but the instructions were even better!
  4. Posts : 72,061
    You're welcome Mustangman. Thank you. :)
  5. Posts : 3
    Win7
    Unable to download desktop
    I have tried the suggestions but cannot download any files. I look in the download folder and its empty. I am unable to save anything to my desktop. Any advice would be most appreciated.
    Tks
    Harry
  6. Posts : 72,061
    Hello Harry, and welcome to Seven Forums.
    Do you have problems with opening any other ZIP files and see it's contents? This is what you should see after double clicking on the downloaded ZIP folder to extract the ICO file in it. Does your antivirus or security program filter ZIP files?
  7. Posts : 13
    when i try to open donwnload library the system tells mi that cant find route.
    please help
    thanks
  8. Posts : 72,061
    Hello JP,
    Where did you save the ZIP file to, and where did you save the extracted ICO file from the ZIP file to?
  9. Posts : 3
    Win7
    thanks Brink but I don't see how the set the download location. Right clicking does not give me the option of saving to a particular location. it seems I can no longer download directly to the desktop. I guess I'm messing up something by not fully understanding libraries. using XP I can always download directly to a folder. However Win7 just doesn't want to accommodate me.
    Harry
