Internet Explorer 9 - Uninstall
    How to Uninstall Internet Explorer 9
    • This will show you how to Uninstall Internet Explorer 9.
    • You can find Internet Explorer 9 here.
       Warning
    Be Careful!
    Make sure you revert any/all customizations made to Internet Explorer 9 prior to uninstalling it to prevent any issues from occuring.
    Step 1: Open the Start Menu, then type View Installed Updates and press enter.
    Step 2: Search for Windows Internet Explorer 9 in the list, and double click on it.
    NOTE: It could take a moment for the entire list to load.
    Step 3: Click on Yes when prompted to uninstall it or not. It should start uninstalling it then.
    Step 4: Once you have completed step 3, click on the Uninstall a program link in the left pane.
    Step 5: If you like, you might also consider hiding this Windows Update to prevent it from being reinstalled.
    Once you've done that, you are finished!
  1. Posts : 18,404
    It leaves the feedback tool installed after IE9 being uninstalled. Might want to add that in there.
    Uninstallation of IE9 and flash square
  2. Posts : 3,639
    Forgot about that (probably since it hardly works to begin with). Thank you for pointing it out Aaron. :)
  3. Posts : 17,322
    Win 10 Pro x64
    Good place to point them to now, nice work!
  4. Posts : 76
    windows 7
    DarkNovaGamer,
    Good job
  5. Posts : 4
    Help me.It says
    "Your system Administrator has disabled Installed Updates."While it is my own personal PC.Then who is admin?
  6. Posts : 400
    Windows 7 Home Premium (Retail) Full version - With SP1
    I installed IE9 RTM and now want to remove it and return to IE8.
    I followed the instructions up to point 2. ( Wasn't very far was it.) I couldn't find Internet Explorer in the list presented. There are no restore point shown in System Restore other than a Windows Update dated today.
    What should I try now?
  7. Posts : 72,062
    Hello jsquareg,
    Could you post a screenshot of your View Installed Updates window showing what you have listed in it?
    When you installed IE9 RTM, did it finish installing and was working properly afterwards?
  8. Posts : 400
    Brink said:
    Hello jsquareg,
    Thank you Brink.
    I was using View Installed Updates from within Programs and Features. When I typed View Installed Updates in the Start Menu's search box I found IE9 and was able to uninstall it. Go figure!
  9. Posts : 72,062
    Great news jsquareg. It sounds like you may not have clicked on the "View installed updates" link while in "Programs and Features". It's the only thing I can think of for why you did not see it previously.
