Fonts - Change
Page 13 of 16 FirstFirst ... 31112131415 ... LastLast
  1. Posts : 72,062
       #120
    Newtothis said:
    Attachment 158048
    It comes up like this. What should I do ?
    Thanks.
    Hello Newtothis,
    Picking up at step 4 in OPTION ONE of the tutorial, you would select a Item from the drop down menu that has a "Font" listed once selected. You could then change the font for that item. Not all items will have a font for it.
  2. Posts : 4,049
       #121
    Thanks Brink
    You've done it again!
    It's a pity MS can't explain Windows adjustments, as accurately and comprehensibly as you can.
  3. Posts : 72,062
       #122
    You're welome Lehnerus, and thank you. :)
  4. Posts : 4,049
       #123
    Font Size?
    I'm a big fan of your work.
    OPTION TWO - Dialog Box Text and Buttons
    Is it possible to change the font size?
    I realize that I could choose a font style/type that is "naturally" larger, but all I want to do is increase the default font size a couple of points.
    Looking at the Registry key, it isn't apparent to me how that would be accomplished.
    See this post for a description of what I wish to change.
    Adjust Font Size
  5. Posts : 72,062
       #124
    I'm afraid that I don't know for that.
  6. Posts : 4,049
       #125
    Thanks (Once Again)
    Thanks for your speedy response. :)
  7. Posts : 1
    Windows 7 64
       #126
    Hi. I'm very sorry if, in asking this, I sound a bit simple, especially if the answer has been given earlier in this thread.
    How do I change the font so that in IE and Firefox and what not, the font that I see on message boards (like this one, for example) is the same font that I saw on message boards in Windows XP? (Thus, from Segoe to Tahoma, yes?)
    I do realize that this has nothing to do with the settings of individual message boards, because I see this same font now wherever I go online, from Google searches to messages boards to, well, everywhere.
    Is it something that I can change via the "personalize" options on the desktop, or does something need to be done to the registry?
    Thanks.
  8. Posts : 4,049
       #127
    Firefox Fonts
    Thanks.
    In Firefox you can change the font in the "Options" window (Firefox button > Options > Options).
    In the "Options" window:
    Click on "Content"
    Click the "Advanced" button
    In the "Fonts"window, choose your fonts and sizes.
    Uncheck the "Allow pages to choose their own fonts, instead of my selections above" box.
    I'm not sure how to modify the IE fonts (I hardly ever use it).
  9. Posts : 72,062
       #128
    Thanks.
    Hello Karsten, and welcome to Seven Forums.
    In addition, here is one for how to change the fonts used in Internet Explorer. See the related links as well for other items to change.
    Internet Explorer - Change Fonts Used for Webpages
  10. Posts : 1
    Windows 7 Enterprise x64
       #129
    Hello Brink,
    Great tutorial, but I still have some problem with Win7 fonts. See my attachement, fonts in Outlook account setting is realy ugly, how can I reset this font to default?
