#30
Dialog boxes out of size
Hi being new on this forum and having a problem.
Hope that this is the right topic to raise this question.
Dialog boxes out of size on Windows 7
Default font?
Perhaps after a TweakUI program the problem occurred that some menus are out of size en donīt fit in their boxes, buttons may not be visible.
Itīs also with User account ctrl and a printer application.
It may have something to do with DPI settings or fontsize because lettertypes appear larger than normal. This may be caused by the Bold Size?
Dialog boxes are not expanding while the menu's underneath do.
Example
This is a Dutch version
If anyone knows the answer to correct this, or the registerkey?
I'm pretty shure that I have accidently changed something in the default font size by playing with theme's. (Aero is set transparant.)
One thing is that the default font has a strike trough as you can see in the picture above, perhaps indicating that its no longer valid?
But don't know how to change that, since as you can see these buttons are out of reach.
It may be done in the register, but it is not clear how to identify the default-font or size.
Perhaps increasing the dialog Box itself would at least made it more usefull.
Changing default fontsize may corrupt dialogboxes
Any help would be welcome.
