Manage - Add or Remove from Computer Context Menu
    How to Add or Remove "Manage" from Computer Context Menu
    This will show you how to add or remove the Manage item from the Computer context menu in the Start Menu, desktop icon, and Windows Explorer navigation pane in Windows 7 and Vista.
    When Manage is selected, it runs the C:\Windows\System32\CompMgmtLauncher.exe file to open Computer Management.
    Removing Manage from the Computer context menu in the Start Menu will not prevent Computer Management from being opened. It only removes it from this context menu.
    EXAMPLE: Computer Context Menu in Start Menu with Manage Added and Removed
    EXAMPLE: Computer Context Menu in Navigation Pane with Manage Added and Removed
    OPTION ONE
    Using a REG File Download
    1. To Add Manage to Computer Context Menu
    Add_Computer_Manage_Context_Menu_Item.reg
    B) Go to step 3.
    2. To Remove Manage from Computer Context Menu
    Remove_Computer_Manage_Context_Menu_Item.reg
    4. Right click on the downloaded .reg, and click on Merge.
    5. Click on Run, Yes, Yes, and OK when prompted.
    6. Log off and log on, or restart the computer to apply.
    7. When finished, you can delete the downloaded .reg file if you like.
    OPTION TWO
    Through the Local Group Policy Editor
    2. In the left pane, click on to expand User Configuration, Administrative Templates, Windows Components, and Windows Explorer. (see screenshot below)
    3. In the right pane, right click on Hides the Manage item on the Windows Explorer context menu and click on Edit. (see screenshot above)
    4. To Add Manage to Computer Context Menu
    A) Select (dot) either Not Configured or Disabled. (see screenshot below step 6)
    NOTE: "Not Comfigured" is the default setting.
    B) Go to step 6.
    5. To Remove Manage from Computer Context Menu
    A) Select (dot) Enabled. (see screenshot below step 6)
    6. Click on OK. (see screenshot below)
  1. Posts : 27
    Windows 7 Professional 64 Bit Service Pk 1
    Hi Shawn,I wonder if this reg fix can help me
    I have the manage on my computer right click,the issue is when i right click it it does nothing
    this is a fresh windows 7 home install with this issue.
    if it's not corrrect could you please direct me what I can do to get this to open.
    thanks for your time
    Vagablonde
  2. Posts : 72,058
    Hello Vagablonde,
    The tutorial below may work better for that instead. It will restore the default registry entries for that, and hopefully sort it for you. :)
    Manage - Fix "File does not have a program associated"
  3. Posts : 27
    Shawn thanks for the quick reply,that was the other option I wondered about .
    as they are reg fix I just wanted to be sure,thanks again.
  4. Posts : 72,058
    You're most welcome. :)
