WMP 12 Internet Streaming
    How To Set Up Windows Media Player 12 For Internet Streaming
    17 Jun 2009
    HOW TO SETUP
    INTERNET STREAMING
    IN WMP 12
    This will show you how to set up internet streaming in windows 7 using windows media player 12.
    This has worked for me im using Windows 7 RC X64 i would assume that it works the same for all. The Screens might look different but should mostly be the same
       Warning
    In order for this to work you must have
    1: Windows Live ID Sign-in Assistant 6.5
    2: A Live ID ( @hotmail.com @msn.com @live.com should all work, or what ever your LIVE ID is)
    3: Your windows accounts do not need the be the same
    4: This MUST be done on both systems or all systems that you want to be able to connect too or connect from
    5: You are able to connect to more then one remote system
    Here's How:
    1. To start open WMP 12
      Once open click at the top of the left side of the window STREAM here in Yellow then click on the Allow Internet Access To Home Media
    2. Click on Link an online ID
    3. Click on Add An online ID provider.
    4. Click here
    5. The last step should have opened this window here.
      Click Downloads Below or Scroll Down the page to get to the downloads make sure you pick the right OS 32-bit OR 64-bit
    6. Either Run or Save then run latter.
      Just Click Run. Let it download start the installer.
      When done click on Finsh.
    7. GO back to WMP 12 you should still have this window here open
      Click on Link A online ID.
    8. Click on Link Online ID
    9. Sign-in with your ID User Name and Password.
    10. Back to WMP 12 one last time
      DONE
  1. Posts : 1
    windows 7
    Besides of this great but incompplete tutorial, you need to do some port forwarding on your routeur:
    TCP EXt 44785 to INT 10245
    and
    TCP EXT 443 to INT 10245
    And of course the PC that will be pushing the files has to be on a home network, not a domain or a public network.
    Enjoy!
  2. Posts : 4,925
    Windows 7 Professional 64-bit
    When I try using the live id assistant I get this error:
  3. Posts : 27
    Vista Business X64 / Win 7 RC X64 / Win t X64 RTM no activation
    and
    Enjoy!
    this tut was not a for alll cases mostly just a fast set up
    i dont know about what ports need forwarding
    but it works for me from home to work from behind a verizon fios set up with just standard settings nothing was done to change router settings also i use wireless to the router
    i would guess your right on it needed to be home network for the computer that pushes the computer at work is not joined to the domain but it is a work private network and i can still connect to my work computer and it will push to my home computer no specail settings or ports forrward going though a sonic firewall
    thanks for the extra info but as i dont know every ones case i will leave the tut as is unless a admin or mod wants to change it any more then it is
    i beleave for most setups this should work just about 75% of the time
  4. Posts : 27
    i dont know what the limit is on the amount of machines that you can link with your live id try unlinking with an account but i dont think theres a limit but i have only used this to stream to my work machine with rc1
    and works
    how many computers do you have your id linked to try to remove it from one of them
  5. Posts : 27
    and
    Enjoy!
    i have tested this from my personal home computer to my work computer with no settings just the way i have the tut and it works
    sonic firewall on the work side no ports forwarded or specail settings needed
    also i would not forward port 443 to your computer unless you have a good reason to be forwarding a ssl or running a web server or any thing else that would need ssl
    from what i can tell this works by using a push when you load wmp it goes out to live id and says what can i connect too it gives you a list of other librarys
    using live id a gateway connection to your other machine and lets each system know how to connect to each other
    this is the same idea as TS GATEWAY in win2k8
    where you can have a remote app run in a as a remote desktop but just that one app window same idea here
    see as win7 and win2k8 is all the same code this is my guess live id just sets up the connections from what i can tell
    your right with the forwards but i still would not forward 443
    if you have upnp on should take care of most of it
    thats why i did not have to forward
    as to if the sonic firewall is set to auto upnp dont know
    Attached Thumbnails Attached Thumbnails WMP 12 Internet Streaming-capture.png
  6. Posts : 4,925
    and works
    thats the trouble Im only linking to this machine. Trouble is because Ive been testing each new build I have installed it each time. I wonder if its remembered that some how.
  7. Posts : 34
    Did not work on mine...
    I recorded the problem with Problem Steps Recorder... (sorry for the foreign language - it's Greek!)
    wmp12_problem.zip - Windows Live
  8. Posts : 27
    djprodg
    did you set up the windows id assistant
    also this this guide was used for the RC1
    but i have sense moved to RTM but i no longer have a job to test this any longer
    or another computer
    so i could only guess
    i did look at your problem file i would guess that you missed a step and did not link widows account with your windows live id account you need to do this on both computers
    but your windows accounts do not need to be the same just only your live id
    hope that helped
  9. Posts : 34
    djprodg
    or another computer
    hope that helped
    Thanks for the help. The problem was caused by a registry cleaner i used (for my first time) and formatted my PC to fix it, then I followed the instructions and it's OK.
    P.S. I will never ever use registry cleaners again...
