Page 30 of 56 FirstFirst ... 20282930313240 ... LastLast
  1. Posts : 5
    Windows 7 not sure how to find the bit
       #290
    I fixed the problem whole device is not ready but now it says " F:\FRST.exe is not recognizable as an internal or external command, operable program or batch file"
  2. Posts : 6,830
    Windows 7 Ultimate 32-Bit & Windows 7 Ultimate 64-Bit
       #291
    When you're booting up the PC . Tap on the F8 key . On the Advanced Boot Options menu choose Repair Your Computer .
    Choose your user name and input the password if you have one if you don't just leave the Password box blank and press [enter]
    On the System Recovery Options window click on Command Prompt
    Inside Command Prompt type in the commands below
    Diskpart
    Press [ENTER]
    list volume
    Press [enter]
    Take note of the drive letter of your flash drive . Once you know the USB drive letter type the command below
    exit
    press [ENTER]
    Now type in this below
    X:\FRST64.exe
    press [enter]
    Change X:\ to your USB drive letter
  3. Posts : 5
       #292
    Thank you for the reply
    I already knew what letter my usb drive was
    The problem is that when i type in X:\FRST.exe
    it says 'X:\FRST.exe' is not recognized as an internal or external command, operable program or batch file
  4. Posts : 6,830
       #293
    Change the X to your actual USB drive letter . It will be different then X . To verify your USB drive letter . Use Diskpart to view the letters .
    Diskpart
    Press ENTER
    List volume
    press [ENTER]
  5. Posts : 5
       #294
    I did
    it didn't work
    it said the does not recognize thing again
  6. Posts : 6,830
       #295
    If you downloaded the 64-bit version
    Type : X:\FRST64.exe
    If you downloaded the 32-bit version
    Type : X:\FRST.exe
    Change X: to your actual drive letter
  7. Posts : 1
    64
       #296
    I am having a problem with step 3. The startup repair has be going on for just under 24 hours now. I am not sure if it is supposed to take this long. Also, when I click cancel, it says that the current repair operation cannot be cancelled. Please help, thanks.
  8. Posts : 1
    I have done all the steps and did not miss anything, but when I restarted my laptop it still goes to the start up repair window. What should I do? Please help. I tried tapping on the F8 button repeatedly on the boot screen (black screen) and it only makes a beeping sound and goes straight to startup repair.
    Thanks so much!
  9. Posts : 7
    Windows 7 Home Premium 64-bit
       #298
    I have something like this I guess. Need a way to get out the startup repair loop on my windows 7 laptop. I skipped to Step 4 but theres no options for Advanced details and etc. What should I do?
  10. Posts : 72,052
       #299
    Hello Pradatorius,
    You might see if you are able to boot from either your System Repair Disc or retail Windows 7 installation media (DVD/USB) to the System Recovery Options screen, then pick up at step 5 in the tutorial.
    Hope this helps, :)
