Page 31 of 56 FirstFirst ... 21293031323341 ... LastLast
  1. Posts : 72,058
       #300
    iamclare said:
    I have done all the steps and did not miss anything, but when I restarted my laptop it still goes to the start up repair window. What should I do? Please help. I tried tapping on the F8 button repeatedly on the boot screen (black screen) and it only makes a beeping sound and goes straight to startup repair.
    Thanks so much!
    Hello Clare, and welcome to Seven Forums.
    Sorry for the late reply.
    Are you able to get to step 3 and 4?
    If not, then you might see if you are able to also do what I posted above for Pradatorius to boot to the System Recovery Options.
    Hope this helps for now, :)
  2. Posts : 1
    Windows 7 Ultimate x36
       #301
    Problem still exists.....
  3. Posts : 1
    Good Morning Guys!
    I've tried the tutorial (Great and Easy tutorial BTW!) and followed it to the letter. I did not encounter any problems during the tutorial.
    However, after completing the tutorial, my system is still stuck in the Infinite Loop.
    I tried doing the tutorial again, and it's still stuck.
    I'm still hesitant to reformat my computer, since it has been running great for 2 years, and there are a lot of programs already installed.
    The problem only started when one of our carpenters suddenly switched off our electricity to make some adjustments.
    Any help would be greatly appreciated! :)
  4. Posts : 7
    The worst thing happened to me:
    The file sizes presented here are approximate estimations, and may vary depending on your system. If any one of them are 0 bytes, then you should stop what you're doing now and seek an alternative method of recovering your system, because Windows cannot function with a 0-byte size registry hive.
    Is there any solution for this? Please, this is urgent.
  5. Posts : 72,058
       #304
    Hello Harun, and welcome to Seven Forums.
    You might see if you may be able to do a system restore at boot using a restore point dated before this happened may be able to help. Otherwise, you may be looking at reinstalling Windows if you did not create a system image that you can restore.
    Hope this helps, :)
  6. Posts : 7
    Thanks Brink, I guess reinstalling is the only solution for me. :)
  7. Posts : 16,163
    7 X64
       #306
    Unless you have shadow copies....Do you think you have any?
    You should be able to boot up external media, ( recovery disc/install disc/usb ) and do a system restore. ( Option 2 in the tut Shawn linked )
      My Computers
  8. Posts : 7
    I don't have any images or copies. Reinstalled Windows and the same happened again. I don't know what to do.
  9. Posts : 72,058
       #308
    Was this a clean install that you did?
    Clean Install Windows 7
  10. Posts : 7
    Yes, that was exactly what I did.
