#120
Sweet, works great, thanks!
will this work if my computer WEI score for aero is 1.9 and the aero effect wont turn on at all
Hello Zekramcross,
Sorry, but no. Aero will have to be able to run for this to work since it uses Aero.
I don't know what I did but I cant see Desktop Windows Manager Session Manager anymore. I did see it when I did this at first but then I can't see it no more and it's disabled
Wait, never mind :) I found my solution here Lost the use of Aero theme? all I did was run troubleshoot and it fixed my my problem Sorry I freaked out oh and I love this! thank you!
Hello PacMan, and welcome to Seven Forums.
Do you have the Desktop Windows Manager Session Manager service listed in your Services at all like in the screenshot below?
I'm not sure what you mean when you say you can't see it, but it's disabled. If it's just disabled, then you should be able to set it to be Automatic, apply, then Start it.
Services - Start or Disable
Hope this helps for now, :)
Hi, it's me and my quirky machine...again.
I used the reg files and logged off and rebooted but the blur effect is still there. Tried both for All Users and Current User.
