Region and Language - Change
    How to change the default Format, Location and System Locale
    How to change your default Region and Language settings
    This will show you how to set your Regional and Language Format, Location and System Locale settings.
    Following the steps outlined below has been known to solve issues such as Sky Player not showing up in Media Center, which is due to discrepencies in the region/language settings
    Here's How:
    1. Open the Control Panel(Category View), then click on Regional and Language. (See screenshot below)
    2. Click the 'Formats' tab (selected by default), then click the Format: dropdown and select the format you require (See screenshot below)
    3. Next, click the 'Location' tab and select your location from the dropdown (See screenshot below)
    4. Next, click the 'Administrative' tab. You will notice 2 options (See screenshot below)
    5. Next, click the 'Change system locale' button and select your location from the dropdown then click OK (See screenshot below)
    Region and Language - Change-region-language-administrative-change-locale-.png
    6. Next, click the 'Copy Settings' button and put a check (tick) in the 2 boxes at the bottom then click OK (See screenshot below)
    Region and Language - Change-region-language-administrative-copy-settings-.png
    You may be prompted for a system restart after the final OK, just click the Restart Now button and allow the system to restart.
       Tip
    For those using language packs and user accounts in more than one language, step 6 is essential to assure all new user accounts are not only set to to desired location and keyboard layout, but it also determines in which language new accounts are created
    That's all there is to it,
    Jeff
  1. Posts : 17,545
    Windows 10 Pro x64 EN-GB
    Very clear, easy to read tutorial. Thanks, Jeff.
    For those using language packs and user accounts in more than one language, step 6 is essential to assure all new user accounts are not only set to to desired location and keyboard layout, but it also determines in which language new accounts are created.
    Kari
    EDIT: Sorry, I have to spread the rep before being able to rep you again
  2. Posts : 6,305
    Thanks Kari, added as a new tip
  3. Posts : 1
    I would like to know if there any way to set this changes by any kind of command line.
    Bat file or something just to double click :)
  4. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    Does this work on all versions of Windows 7? I see no mention of it being only for Pro, Ultimate and Enterprise.
  5. Posts : 17,545
    For language packs you need Ultimate or Enterprise, other than that the regional and language settings as told in this tutorial can be found and changed on all editions.
    Kari
  6. Posts : 24,479
    Thanks Kari.
  7. Posts : 2
    windows 7 ultimate x64
    I do this over and over again, like 30 times a day.
    how can i write a code to select all settings to my installed Lp.cab?
    ENG to TR, via one click?
